Thread: Injector flow rate OR Cylinder gain?
Results 1 to 20 of 32
  1. #1 Re: Injector flow rate OR Cylinder gain?
    Feb 2009
    flintnasty MI
    I would just let the trims do what they want. Its not going to change anything by "fixing" them because all you are going to do is add fuel in the tune so it has to "do less work" in the LTFT. If anything the +16 cruising helps you get a bit of a lean cruise going.
    If it isnt broke dont fix it.
  2. #2 Re: Injector flow rate OR Cylinder gain?
    Arizona
    No.
  1. Anyone know the going rate on a mp112?
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 08-08-2013, 05:31 PM
  2. Compression Rate
    By Bigheadedon in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-04-2013, 09:32 AM
  3. Regal GS Spring Rate vs 40th Anniversary Spring Rate
    By 40th in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2011, 10:57 AM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
