Thread: Injector flow rate OR Cylinder gain?
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Injector flow rate OR Cylinder gain?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Set your injectors to their actual value and then use this guide if you want everything else to work correctly http://www.grandprixforums.net/threa...ur-car-for-e85 ....... Im a little biased though.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #22 Re: Injector flow rate OR Cylinder gain?
    Mar 2014
    Tucson
    Quote Originally Posted by Frosty View Post
    And I may also try that. I like the idea of my IFR number matching what I actually have physically installed in the car.
    But that leads me back to my OP. What is "cylinder gain?" Can someone explain it to me?
  3. #23 Re: Injector flow rate OR Cylinder gain?
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by BrandonHall10 View Post
    Not.to.thread jack.but where is this cylinder gain in dhp? It looks like under injector skew but in dhp the value is 100. Do we change this to 120?
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  4. #24 Re: Injector flow rate OR Cylinder gain?
    Apr 2011
    South Dakota
    It will let you trim individual cylinders fuel ratio. Useful if you have a manifold design that doesn't feed evenly or one cylinder runs hotter then others.... ect ect. For 99.9% of people it should be set even across the board. For us its useful for if you max out your IFR table or want to run e85!
    I love Decker<3
  5. #25 Re: Injector flow rate OR Cylinder gain?
    Apr 2011
    South Dakota
    If there are six of them and they are all set to 100 then that sounds correct.
    I love Decker<3
  6. #26 Re: Injector flow rate OR Cylinder gain?
    Montgomery, IL
    Yes cylinders 1 through 6. Looks just like your pic in hp but numbers different.
  7. #27 Re: Injector flow rate OR Cylinder gain?
    Mar 2014
    Tucson
    So, let's say for example, I want one tune for E85, and one for 91. Based on the "Frosty" method;
    1.) I would set the IFR to 42.5 across the board (I'm running lucas #42.5's) for both tunes. Then on my E85 tune, I would set the cylinder gains to 1.225, and set them to 1.0 for gasoline?
    2.) Also assuming I would need/want to adjust the cyl gain on the E85 tune to "center" my trims around zero. (That value would be dependent on ethanol content, right?)
  8. #28 Re: Injector flow rate OR Cylinder gain?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Too bad we can't monitor KR per cylinder (as far as I know), or it might be more useful. More fuel could possibly be added to the middle (hotter) cylinders to reduce knock if those cylinders are prone to it. I know that the newer 5.0 mustangs often have heat/detonation issues with cylinder #8, which tuners sometimes compensate for by adding more fuel to that particular cylinder. Probably not much to gain on our platform, but hey, enthusiast problems.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  9. #29 Re: Injector flow rate OR Cylinder gain?
    Apr 2011
    South Dakota
    Pretty much. I usually leave it at 1.2 all winter and 1.25 all summer. It varies a bit but nothing the stock fuel trimming cant handle.
    I love Decker<3
  10. #30 Re: Injector flow rate OR Cylinder gain?
    Mar 2014
    Tucson
    Sounds good. Thanks!
    I've been debating buying one of those fuel testers...
    http://www.quickfueltechnology.com/s...test-tube.html
  11. #31 Re: Injector flow rate OR Cylinder gain?
    Feb 2009
    flintnasty MI
    Go back to a stock tune and set the lean code to no reporting if it bothers you.
  12. #32 Re: Injector flow rate OR Cylinder gain?
    Bastard Reptile's Avatar
    Kansas City, MO
    Right, because that code will never come in handy in the future in case you have a real problem.
  1. Anyone know the going rate on a mp112?
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 08-08-2013, 05:31 PM
  2. Compression Rate
    By Bigheadedon in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-04-2013, 09:32 AM
  3. Regal GS Spring Rate vs 40th Anniversary Spring Rate
    By 40th in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2011, 10:57 AM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
