I would make adjustments to the MAF table to zero the LTFTs out as close to 0.0 as you can get them. Just me though.
While I'm a pretty good advocate for doing MAF tunes, for cruise and driveability.....I'd still recommend doing the IFR table to get a base line. When you change injectors it helps to get the flow rate as close as you can first, because if you tweak the MAF table too much after an injector swap you're gonna have shifting problems with the trans.
