Thread: Low timing?
Results 1 to 20 of 26
  1. #1 Low timing?
    gardner,mass
    Hey i am trying to figure out why im getting such low timing. How do people see 18* with a 3.4 gen3 or 3.6 gen5?
    My a/f is 10.5-11.0 wot boost is around 10-11 and im seeing like 11-13*. Kr sometimes hits 1-2 at shifts or 3rd gear.
    Seems like something isnt right and i should be able to get more out of this car.
    Im also noticing latly the car randomly bogs down and up like its falling on its face when cruising at like 2k rpm. Put brand new delphi maf in and same results.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Low timing?
    Is the torque converter not unlocking and that's why it feels dead?
    Your fueling shouldn't be in the 10s either.
    Your car is stock apart from headers. Not that much to take advantage of. Intercooler or cam would be the only worthwhile mods to look into next. As for why it's not running right, there could be a million and one different reasons.
    So when you see 11-13* of timing, do you see any KR as well? If not, that's all that is being commanded. Thank your tuner for that. If you see KR, again, your tuner should have suggested a larger pulley or that your car was in poor mechanical condition and required service before a smaller pulley.
  3. #3 Re: Low timing?
    Banned
    CT
    IIRC we tried more timing and the car knocked like mad.
    You were also getting massive part throttle knock, so I backed cruise timing down a bit and it went away.
    If you want to bring it down I'll be happy to see if it'll take more timing.
  4. #4 Re: Low timing?
    Oct 2011
    Puyallup WA
    With stock cam and rockers would see a lot of part throttle kr with agressive cruise timing...I'm sitting on 13* timing wot with my xp header car on 3.3...prob could push it out a little farther but kinda playing it safe for now...stock rockers and cam with 11.7 afr didn't really like much more then 13* would starting getting kr
    08 G8 GT - exhaust Tune
  5. #5 Re: Low timing?
    gardner,mass
    Car is starting to bog down even more. Im kind of thinking fuel pump. When the car bogs my afr go to 17+. I was getting this befor i blew my old trans and replaced it with this 112k junkyard unit including converter. This trans pulls great.
  6. #6 Re: Low timing?
    Fuel pressure gauge would tell you for sure.
  7. #7 Re: Low timing?
    Arizona
    You shouldve never bothered with a tune. with it knocking like that in the first place....get your fueling right and everything will work out for you...
  8. #8 Re: Low timing?
    gardner,mass
    I didnt really think i had fueling issues at the time. My fuel pressure tester isnt long enough to be able to go for a drive but my fuel pressure at idle is more than perfect. Think ima get a nice electronic one for my empty gauge pod and also upgrade the fuel pump. Anyone have any recommendations for both? Also i want a non venturi seeing im an 04+ right with the returnless system?
  9. #9 Re: Low timing?
    find a long hose for the tester. pop it out the hood, then drive it.
  10. #10 Re: Low timing?
    Arizona
    Have you pulled your plugs yet to verify lean conditions?
  11. #11 Re: Low timing?
    gardner,mass
    Well called that from a mile away..... Pump just died lol
  12. #12 Re: Low timing?
    well there ya go lol
  13. #13 Re: Low timing?
    gardner,mass
    When i say a mile. Thats literally. Drove to get a coffee half mile up the road came home and tried to restart and pump was dead rofl
  14. #14 Re: Low timing?
    Florida
    any apologies to the guy who tuned your car???
  15. #15 Re: Low timing?
    gardner,mass
    Quote Originally Posted by Z34Phoenix View Post
    Huh? I wasnt calling Nick out at all..... I was just stating the fact that the car seems like something isnt right mechanically and could probly see alot more timing because of....
    On a second note, weirdest **** ever. So i pulled the pump and figured ide put direct power to it to test it and it worked even though the fliters were dirty as ****. So i put it back in and pump still wouldnt turn on so i tested my power wire and noticed that somehow my fuel pump fuse fell out..... How does that happen lol? I have the most random worst luck. But i got a delphi pump coming and ima replace the stock unit anyway looking at those fliters. I tried cleaning them with brake clean but didnt really do ****. Car is still bogging down. Ima pull plugs and check them to see if they are getting fouled because im running 104s and seeing 10-11 afr.
    How can i tell if the torque converter is in fact not unlocking? I see there is torque converter slip on my aeroforce but when im scanning it and the car bogs there really isnt any change.
  16. #16 Re: Low timing?
    gardner,mass
    Ist the fuel pressure supposed to raise when going going wot? Mine drops down to 55 psi. but at idle sits around 60.
  17. #17 Re: Low timing?
    Oct 2011
    Puyallup WA
    04+ is a set pressure 03 older have a regulator to increase pressure at wot
  18. #18 Re: Low timing?
    gardner,mass
    Quote Originally Posted by wa04compg View Post
    Thankyou. So should it stay at a steady 60-62 psi?
  19. #19 Re: Low timing?
    Oct 2011
    Puyallup WA
    No because boost works against what the fuel pump is trying to output
  20. #20 Re: Low timing?
    Oct 2011
    Puyallup WA
    Or at least that's how u understand it
  1. Timing?
    By GTPgasm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2014, 07:26 AM
  2. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  3. To add timing or not...
    By bobeebob in forum PCM Tuning
    Last Post: 12-06-2012, 10:33 PM
  4. Timing
    By redskinman73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2011, 01:48 AM
  5. N/A Cam timing
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 01:12 AM
