Thread: P0053 & P0136 code help
Results 1 to 10 of 10
  1. #1 P0053 & P0136 code help
    SE Level Member fmayo's Avatar
    massachusetts
    I hate emissions codes....my check engine light came on and I ran the car to Autozone where they pulled codes P0053 and P0136. I replace both O2 sensors but still see the check engine light. Being in Massachusetts, I need to resolve it to get an inspection sticker. Advice?
  2. #2 Re: P0053 & P0136 code help
    Oct 2011
    Toledo, OH
    Did you clear the codes after changing the sensors?
    I'd go and check the harnesses for any damage.
    7"
  3. #3 Re: P0053 & P0136 code help
    massachusetts
    Thanks
    I can turn a wrench, but I'm a noob with codes & electrical issues. I thought the computer would read clean if the problem had been fixed and the light would go off on its own. How do I clear the codes?
    I did inspect the wiring quickly when I changed the sensors and did not see any obvious problems there.
  4. #4 Re: P0053 & P0136 code help
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Most codes will go of within 2 cycles of the problem being fixed. I'm not 100% sure how long/ what dictates a 'cycle' but I think like 20 minutes of highway driving at temp is a cycle. I've heard multiple things
  5. #5 Re: P0053 & P0136 code help
    Oct 2011
    Toledo, OH
    Easiest way is to disconnect your battery for an hour. Since you live in an emissions state, I don't know if Autozone etc will clear codes for you.
    7"
  6. #6 Re: P0053 & P0136 code help
    massachusetts
    Thanks!
    I'll try disconnecting the battery tonight.
  7. #7 Re: P0053 & P0136 code help
    i got one of them cheap 12 dollar scanners off ebay. work just perfect for scanning and clearing codes. parts stores, most wont clear it for you.
  8. #8 Re: P0053 & P0136 code help
    massachusetts
    Success!! (I think). Disconnected the battery last night for an hour or two. Drove to work this morning and no check engine light.
    Thanks everyone.
  9. #9 Re: P0053 & P0136 code help
    Most codes are set to two bad tests to turn on the MIL and three good tests in a row to turn off.
  10. #10 Re: P0053 & P0136 code help
    massachusetts
    Thanks again. Replacing the (2) O2 sensors seems to have done the trick. Once I disconnected the battery for a while, the light has stayed off for a couple of days.
    Of course, I did get a flat tire on the way to work this morning.....dammit, it's always something.
    This weekend I have to see if I can get an inspection sticker with a bad strut.
  1. HELP Needed! Car surging P0102 code and P1655 code im STUMPED
    By 97gtpjoe in forum General Tech Discussion
    Last Post: 02-06-2014, 12:15 PM
  2. P0420 & P0136 Problem and How I fixed it
    By brised in forum General Grand Prix Discussion
    Last Post: 08-08-2012, 01:24 AM
  3. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  4. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  5. 05 GP Base P0053 and P0520 codes
    By Yonkerse in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-18-2011, 10:50 AM
