Thread: Timing
Results 1 to 18 of 18
  1. #1 Timing
    Nov 2011
    Knox, IN
    I just bought a 98 Grand Prix SE. This is the first Pontiac I have ever owned and the first vehicle I have ever owned that has a distributorless ignition and I am at a loss at the moment. I changed the plugs and wires and the car still has a rough idle and the rpms fluctuate while going down the road. anybody please help me. How do I reset the timing in this car?
  2. #2 Re: Timing
    Omaha, NE
    It doesn't sound like timing. It sounds like a miss. It could be a bad coil pack, or clogged fuel filter/ bad fuel pump. It could be a bad crank position sensor though.
  3. #3 Re: Timing
    Charles City, IA
    He beat me to it ^
    SMGPFC Two Nipple General
  4. #4 Re: Timing
    engine type mileage, and the check engine light on?
  5. #5 Re: Timing
    Charles City, IA
    Not a crank sensor tho, that would just cause the car to have no spark on any cylinder.
  6. #6 Re: Timing
    Minnesota
    First thing would be to check all the wires then check all the plugs (Check for cracks in the porcelain). If those are good I would take two wires off the coil pack (that are next to each other) at a time and crank it over to see if it arcs between the two terminals on the coil pack to see if that is good. If you still can't find an issue I would keep going with the stuff above and possibly more.
  7. #7 Re: Timing
    Nov 2011
    Knox, IN
    Thank you for all of your input I will check the coils and see if that is the problem. I will post my findings later today. As somebody above asked it is a 1998 Grand Prix with the 3.8 naturally aspirated. the "service engine soon" light is on.
  8. #8 Re: Timing
    Tell us what code it is then get back to us...
    You can get it read at any local auto parts store for free.
  9. #9 Re: Timing
    St. Louis
    Ok, I'll say it. Are you 100% sure you have the plug wires in the correct order? I mean don't just assume they are, find the order on here or in a manual and check them 1 by 1. It's not incredibly hard to swap 2 cylinders and have it run like junk. Happens quite often. Don't trust that the previous owner had them correct either.
  10. #10 Re: Timing
    utah
    from left to right front is 1 3 5 rear is 2 4 6..numbers are one the coils
  11. #11 Re: Timing
    ^^Sometimes
    If not...
    Top to bottom like so...
    6
  12. #12 Re: Timing
    utah
    i was talking about the cylinders not the packs.
  13. #13 Re: Timing
    Ohio
    but hes saying that the coil packs could have been switched up before lol
  14. #14 Re: Timing
    utah
    ^true story
  15. #15 Re: Timing
    Ohio
    nah i lied lol
    or did i?
  16. #16 Re: Timing
    Quote Originally Posted by 99PGPGT View Post
    nah i lied lol
    or did i?
    We know you are.
    What you aren't.
    Twice removed.
    Maybe.
    Get it?
    Good.
  17. #17 Re: Timing
    Nov 2011
    Knox, IN
    Thank you all again for your input. I changed the plug wires and it runs awesome now. the code said cyl. 3 misfire so i cleaned all the plugs and changed the wires the car runs like a top now. anybody have any tips on fuel milage? the car already gets good milage I just wanna get the most out of it, I'm a college student lol. I'm sure some of you know how that goes. Any ideas will be greatly appreciated.
  18. #18 Re: Timing
    St. Louis
    Well, since most of my driving is highway at or around 60-65mph, I can squeeze about 425 miles out of a full tank, and that is down to dangerously empty. Not sure what the MPG works out to, never did the math. Not sure on the city mileage.
  1. Such a thing as to much timing?
    By Sandman in forum PCM Tuning
    Last Post: 03-14-2011, 08:28 PM
  2. N/A Cam timing
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 01:12 AM
  3. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  4. Should I increase my timing
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 03:18 PM
  5. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
