Thread: Low timing?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Low timing?
    Jun 2013
    Hollywood ,FL
    Gin mine drops to and sometime sputters at wot meaning pressure will be at 60 and time spike down to 55 for a milli sec check maf tables under tune my car would do thay at higher rpm at times go pig lean and car would feel like not getting fuel I would think it was the fp now im having problems where my car leabs out at higher rpms and sputters at time low end rpm
  2. #22 Re: Low timing?
    Feb 2009
    flintnasty MI
    I think you might have a problem. ... http://www.isitlowt.com
  3. #23 Re: Low timing?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Dangit Dark... I just clicked that link on my work phone! Haha
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  4. #24 Re: Low timing?
    gardner,mass
    In case anyone was wondering. I retuned the car and the issue went away. After i locked in my fuel trims it was gone. Im guessing because they were so far off it was simulating a bad maf cus thats one of the known causes for this problem.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #25 Re: Low timing?
    Jun 2013
    Hollywood ,FL
    What did u lock in your fuel trims too
  6. #26 Re: Low timing?
    Sweet...good job
  1. Timing?
    By GTPgasm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2014, 07:26 AM
  2. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  3. To add timing or not...
    By bobeebob in forum PCM Tuning
    Last Post: 12-06-2012, 10:33 PM
  4. Timing
    By redskinman73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2011, 01:48 AM
  5. N/A Cam timing
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 01:12 AM
