Thread: Using EGR for DHP input
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
SnowFlake Using EGR for DHP input 01-29-2012, 05:10 PM
matt5112 Re: Using EGR for DHP input 01-29-2012, 05:19 PM
SnowFlake Re: Using EGR for DHP input 01-29-2012, 05:27 PM
matt5112 Re: Using EGR for DHP input 01-29-2012, 05:32 PM
Swiggles You'll be better off using... 01-29-2012, 05:34 PM
SnowFlake Re: Using EGR for DHP input 01-29-2012, 06:09 PM
BillBoost37 Re: Using EGR for DHP input 01-30-2012, 08:45 AM
SnowFlake Re: Using EGR for DHP input 01-30-2012, 10:42 AM
darkhorizon Re: Using EGR for DHP input 01-30-2012, 10:42 AM
SnowFlake Re: Using EGR for DHP input 01-30-2012, 03:09 PM
darkhorizon Re: Using EGR for DHP input 01-30-2012, 03:20 PM
SnowFlake Re: Using EGR for DHP input 01-30-2012, 03:25 PM
darkhorizon Re: Using EGR for DHP input 01-30-2012, 08:42 PM
BillBoost37 Re: Using EGR for DHP input 01-31-2012, 07:34 AM
darkhorizon Re: Using EGR for DHP input 01-31-2012, 09:35 AM
SnowFlake Re: Using EGR for DHP input 02-04-2012, 10:52 AM
BillBoost37 Re: Using EGR for DHP input 02-06-2012, 08:00 AM
darkhorizon Re: Using EGR for DHP input 02-06-2012, 09:28 AM
SnowFlake Re: Using EGR for DHP input 02-06-2012, 12:20 PM
darkhorizon Re: Using EGR for DHP input 02-06-2012, 12:36 PM
TheOtherNick Re: Using EGR for DHP input 02-07-2012, 11:48 PM
SnowFlake Re: Using EGR for DHP input 02-07-2012, 11:50 PM
TheOtherNick Re: Using EGR for DHP input 02-07-2012, 11:55 PM
SnowFlake Re: Using EGR for DHP input 02-07-2012, 11:57 PM
BillBoost37 Re: Using EGR for DHP input 02-08-2012, 06:41 AM
SnowFlake Re: Using EGR for DHP input 02-08-2012, 02:54 PM
FoSHO99 Re: Using EGR for DHP input 02-08-2012, 04:15 PM
SnowFlake Re: Using EGR for DHP input 02-08-2012, 06:37 PM
FoSHO99 Re: Using EGR for DHP input 02-08-2012, 07:59 PM
RegalGS98s Re: Using EGR for DHP input 02-10-2012, 07:33 AM
darkhorizon Re: Using EGR for DHP input 02-10-2012, 08:56 AM
  1. #1 Re: Using EGR for DHP input
    Charles City, IA
    I have a write up on here saying step by step what I did. IIRC you have an ngk afx so everything will be the same except for setting up your pid in dhp.
    SMGPFC Two Nipple General
  2. #2 Re: Using EGR for DHP input
    Banned
    CT
    My wb02 is logging just fine, I figured out the PID. However it'll freeze after I've had it on for more than a couple minutes... I can't figure that out.
    It's wired into the A/D input on the DHP.
  3. #3 Re: Using EGR for DHP input
    Charles City, IA
    If you wired it into the egr circuit you shouldnt have to run any wire to the box just log the egr pid. and convert it to afr with the simple calc.
  4. #4 Re: Using EGR for DHP input
    Banned
    CT
    It's the 2 analog wires from the wb to the dhp. The EGR has my IAT2 in it.
  5. #5 Re: Using EGR for DHP input
    So you didn't wire your WB through the EGR?
    Why's it locking up on you?
    Do you think it has anything to do with your deleting things in the registry on your pc problem?
  6. #6 Re: Using EGR for DHP input
    Banned
    CT
    My computer is fine. Only the wideband gauge locks up, all the other gauges function normally.
  7. #7 Re: Using EGR for DHP input
    Jan 1970
    Maquoketa, Iowa
    The wideband/egr reading in your dhp scanner is locking up, or is the actual wideband locking up? You should be using UVScan to scan if you aren't already.
  8. #8 Re: Using EGR for DHP input
    Banned
    CT
    Quote Originally Posted by FoSHO99 View Post
    Just the wideband gauge in my DHP scanner. The gauge on my dash is fine and so are all the other DHP gauges.
    I tried UV Scan and I really didn't like it.
  9. #9 Re: Using EGR for DHP input
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by SnowFlake View Post
    Well, it's either get used to using uvscan and make yourself like it or live with the problems of the dhp scanner... There are more problems to come if you go with the later.
  10. #10 Re: Using EGR for DHP input
    GT Level Member RegalGS98s's Avatar
    NJ
    If it's a registry problem with just the DHP program like Bill was saying. Use Revo Uninstall to fully uninstall the program and then reinstall it. Use the Advanced uninstall option so it'll delete any remaining files and registry entries. It can be found at download.com. If it's a problem with the design of the program and that part of the program keeps running out of memory to cause the freeze ups, you can probably increase the memory values so it at least works longer if not stop from freezing up. I haven't used a tuner yet, I'm just looking at it from a software perspective.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  11. #11 Re: Using EGR for DHP input
    Feb 2009
    flintnasty MI
    There is just a glitch in the way the DHP scanner reads the hardware PIDs... its a known fatal bug, there is no fix for it other than to use a scanner that works correctly.
  1. Vss input help!!!
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-07-2010, 05:41 PM
  2. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
  3. Need some input
    By bigtom9492 in forum Visual/Body Modifications
    Last Post: 11-16-2009, 07:29 PM
  4. Need input on set up!
    By GTP4 in forum PCM Tuning
    Last Post: 10-27-2008, 08:53 PM
  5. just want some input
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 01:18 PM
