Thread: Using EGR for DHP input
Results 1 to 20 of 31
SnowFlake Using EGR for DHP input 01-29-2012, 05:10 PM
matt5112 Re: Using EGR for DHP input 01-29-2012, 05:19 PM
SnowFlake Re: Using EGR for DHP input 01-29-2012, 05:27 PM
matt5112 Re: Using EGR for DHP input 01-29-2012, 05:32 PM
Swiggles You'll be better off using... 01-29-2012, 05:34 PM
SnowFlake Re: Using EGR for DHP input 01-29-2012, 06:09 PM
BillBoost37 Re: Using EGR for DHP input 01-30-2012, 08:45 AM
SnowFlake Re: Using EGR for DHP input 01-30-2012, 10:42 AM
darkhorizon Re: Using EGR for DHP input 01-30-2012, 10:42 AM
SnowFlake Re: Using EGR for DHP input 01-30-2012, 03:09 PM
darkhorizon Re: Using EGR for DHP input 01-30-2012, 03:20 PM
SnowFlake Re: Using EGR for DHP input 01-30-2012, 03:25 PM
darkhorizon Re: Using EGR for DHP input 01-30-2012, 08:42 PM
BillBoost37 Re: Using EGR for DHP input 01-31-2012, 07:34 AM
darkhorizon Re: Using EGR for DHP input 01-31-2012, 09:35 AM
SnowFlake Re: Using EGR for DHP input 02-04-2012, 10:52 AM
BillBoost37 Re: Using EGR for DHP input 02-06-2012, 08:00 AM
darkhorizon Re: Using EGR for DHP input 02-06-2012, 09:28 AM
SnowFlake Re: Using EGR for DHP input 02-06-2012, 12:20 PM
darkhorizon Re: Using EGR for DHP input 02-06-2012, 12:36 PM
TheOtherNick Re: Using EGR for DHP input 02-07-2012, 11:48 PM
SnowFlake Re: Using EGR for DHP input 02-07-2012, 11:50 PM
TheOtherNick Re: Using EGR for DHP input 02-07-2012, 11:55 PM
SnowFlake Re: Using EGR for DHP input 02-07-2012, 11:57 PM
BillBoost37 Re: Using EGR for DHP input 02-08-2012, 06:41 AM
SnowFlake Re: Using EGR for DHP input 02-08-2012, 02:54 PM
FoSHO99 Re: Using EGR for DHP input 02-08-2012, 04:15 PM
SnowFlake Re: Using EGR for DHP input 02-08-2012, 06:37 PM
FoSHO99 Re: Using EGR for DHP input 02-08-2012, 07:59 PM
RegalGS98s Re: Using EGR for DHP input 02-10-2012, 07:33 AM
darkhorizon Re: Using EGR for DHP input 02-10-2012, 08:56 AM
  1. #1 Using EGR for DHP input
    Banned
    CT
    I'm looking to add either my wideband or LIM temp sensor via the EGR. I've heard a ton of people talking about it but I've never seen how. As of now, when I want to see what the delta temps are I have to disconnect my IAT sensor and use that, I also can't log my wideband and I would like to start doing that via the EGR or the A/D input on the DHP itself.
    Any ideas?
  2. #2 Re: Using EGR for DHP input
    Turning the input into useful data depends on your data logging software.
  3. #3 Re: Using EGR for DHP input
    Banned
    CT
    I have a DHP...
  4. #4 Re: Using EGR for DHP input
    I dont use DHP.
    Not all DHP users use the "built in" software to log.
    Quincy, Mass
    You'll be better off using the inputs on the dhp over the egr.
    No more GP 04 Impala SS Indy:
  6. #6 Re: Using EGR for DHP input
    Banned
    CT
    I just need to know what is physically wired. I'll figure out the rest, thanks!
  7. #7 Re: Using EGR for DHP input
    Well..you want to bring the WB analog wires to the green thing on the side of the DHP then setup the gauge. I think DHP has most WB's already setup and you can import them right from the software. Since you have DHP, login to the Powertuner site and do a search (since I've never set one up with DHP, I'm not sure if my advice is any good at all)
    On the post rotor temps. Take a look at the stock IAT and replicate the input wire, then run your other wire to the EGR pin that you'll be using to bring that data back to the DHP and reconfigure the EGR input to be the same as the IAT. Heck..probably could copy that IAT config for it.
  8. #8 Re: Using EGR for DHP input
    Banned
    CT
    So, tap the lighter colored IAT wire for juice and run that to the LIM IAT... then take another wire from the LIM IAT and put it into the middle pin on the EGR plug?
    I've already got the WB up and running on the DHP... now I just need to figure out the post blower IAT and I'll be all set.
    BTW I'm using an IAT2 sensor out of a 2009 Shelby GT500KR, it was 15 bucks shipped on ebay.
    Part number TS10098
  9. #9 Re: Using EGR for DHP input
    Feb 2009
    flintnasty MI
    The brown EGR wire gets the 5 volt output from the wideband to go to it. I sometimes put the wideband ground to the EGR ground to increase accuracy.
    The IAT does not operate on voltage, so you would need to build a voltage divider, and setup your own calibration in order to run it on a 5v input somewhere (ac/egr/dhp box). I would probably build the voltage divider with a 5k ohm resistance, and splice into the 5v rail on the PCM.
    I ended up making a little switch for my 2 temp sensors... Make 1 run, then switch and make the run again after the intercooler recovers. Preintercooler temps shouldnt vary much in a few miles.
  10. #10 Re: Using EGR for DHP input
    Banned
    CT
    Does anyone know exactly what each wire in the EGR plug does? There's 5 of them.
  11. #11 Re: Using EGR for DHP input
    Feb 2009
    flintnasty MI
    Pin D grey = 5v reference
    pin c brown = pintle position
    pin B black = pintle position ground
    pin A red = valve control
    pin E white = valve control
    Colors are different sometimes.
  12. #12 Re: Using EGR for DHP input
    Banned
    CT
    From left to right my wires are light brown, light brown, tan, black, light brown.
    I don't see any letters on the plug.
  13. #13 Re: Using EGR for DHP input
    Feb 2009
    flintnasty MI
    Quote Originally Posted by SnowFlake View Post
    and you call me an idiot.
  14. #14 Re: Using EGR for DHP input
    Nick, look closer. All the plugs on the car are labeled with letters or numbers.
  15. #15 Re: Using EGR for DHP input
    Feb 2009
    flintnasty MI
    Even if it isnt labled (which they are) it is easy to determine if you know the order of the first 5 letters of the alphabet, and 2 wire colors that do line up.
  16. #16 Re: Using EGR for DHP input
    Banned
    CT
    I have the sensor wired up to the EGR... it seemed like it was working for a few pulls and then it just started moving incoherently. I tried hooking it up to the IAT that's still in my intake tube and the same **** happens... just moves without any sort of relevance to what's actually going on.
    Voltage to the EGR is 4.84 at all times when I wired it up independently instead of tying in power from the regular IAT.
  17. #17 Re: Using EGR for DHP input
    So what's wrong?
  18. #18 Re: Using EGR for DHP input
    Feb 2009
    flintnasty MI
    Bill, it will never work without a proper voltage divider circuit. This clown is just completely lost.
  19. #19 Re: Using EGR for DHP input
    Banned
    CT
    Quote Originally Posted by darkhorizon View Post
    Excuse me for not being a pro in how the PCM interprets voltage from the IAT... I've since figured it out and am happily logging IAT2.
  20. #20 Re: Using EGR for DHP input
    Feb 2009
    flintnasty MI
    damn ur a bad ass.
    and oh, you wouldnt really need to be an expert to realize every other sensor on the motor that uses 5 volts has a ground and a signal output wire on it... An expert would not be required to make that observation.
  1. Vss input help!!!
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-07-2010, 05:41 PM
  2. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
  3. Need some input
    By bigtom9492 in forum Visual/Body Modifications
    Last Post: 11-16-2009, 07:29 PM
  4. Need input on set up!
    By GTP4 in forum PCM Tuning
    Last Post: 10-27-2008, 08:53 PM
  5. just want some input
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 01:18 PM
