Try rolling onto boost with the gear selector in 2.
Also as I said before, AE is not going to do much for fueling. If you want to lean things out use PE not your injector constants. PE is the only adjustment your pCM needs to add or subtract fuel in PE.... and it works very well and is extremely easy to adjust.
