Thread: Tuning for a 3.5" pulley upgrade
Results 21 to 40 of 60
  1. #21 Re: Tuning for a 3.5" pulley upgrade
    Out West
    the table can be played with. but i've found my car likes it a lot more when richening just a touch going into 2nd gear.
  2. #22 Re: Tuning for a 3.5" pulley upgrade
    Feb 2009
    flintnasty MI
    Stock is fun
    Its 12.x base minus a point or more depending on time and engine speed.
    Too much inconsistency if you're trying to dial the maf/injectors in.
    Its more than consistant enough... It doesnt change much at all really, and its linear.
  3. #23 Re: Tuning for a 3.5" pulley upgrade
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    What really annoys me is when people start a thread, drum up all sorts of help, and then never post the solution. What I'm getting at is that I've come across 4 page threads the same as this.....without the OP posting the fix.
    There is a sabrewings thread like this, but it appears he hasn't used the site in years.
    Anyway, i'm using the DHP AFR vs time vs RPM table which richens less with time in PE than does stock.
    That didn't improve anything. It's more like increasing KR with increasing boost. Thinking of trying a stupid PE AFR like 10:1 or 13:1 to find the direction of improvement.
  4. #24 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    So just to re-iterate, the biggest of my concern now is when I roll on throttle, it runs pretty good until hitting PE where I get a couple degrees KR, then with more throttle KR goes up to 8ish.
  5. #25 Re: Tuning for a 3.5" pulley upgrade
    Do you get the same if you stand on it?
    Have you ruled out mechanical problems?
    Faulty/improperly installed knock sensors?
    Do you have a WB?
  6. #26 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    I usually let off as soon 6* KR shows up.
    As far as mechanical problems, yeah, I think it's OK. No misfires. Thought maybe a vac leak at first, but then I would expect pegged fuel trims. I think.
    Knock sensors should be fine, there are no CEL.
    No WB.
  7. #27 Re: Tuning for a 3.5" pulley upgrade
    Feb 2009
    flintnasty MI
    Quote Originally Posted by mechguy View Post
    Going too far in one direction is not going to show your solution.
    Typically I find alot of knock if you ever go too far rich...
  8. #28 Re: Tuning for a 3.5" pulley upgrade
    Florida
    I should have caught this earlier, but:
    i see on the scans a commanded AF of 11.9... i would say lower that try 11.7 or 11.6 see if it gets better or worse.
    if that doesnt work reset back to what it was and then use your IAT spark table to pull 1-2* of timing IE -2 on it. no need to change the entire table but say from 32*-122* you can start like 1/3rd the way down till the bottom so your cruse isnt effected.
    if your KR is not bad until after you get into PE then your AE is fine and you need either less Timing or more fuel.
  9. #29 Re: Tuning for a 3.5" pulley upgrade
    GT Level Member jdmgtp's Avatar
    MI
    I have similar mods to you but I have a catback and 1.9 rockers which don't make much a difference in tuning. I start at 20 degrees of timing and 11.5:1 a/f at the bottom of 1st gear and richen up to 10.8:1 with 16 degrees by the top of second. Richening it up and pulling timing a couple degrees are the only way I can run knock free at the top of 2nd. It's possible my valves are still carbon'd up. Some cars can run more timing and leaner mixtures some less, you'll have to see what your car will allow.
    When tuning a knock prone car I like to start at 11.0 a/f ratio and progressively add timing. This gives me an idea of what timing it will like with leaner mixtures. Try running 11.2 a/f ratio and stock timing as a starting point and see if you get knock. If you can't run at least 11.0 a/f ratio and stock timing you might need more mods.
    Also, I'd like to see a better scan. Something like this: get up to 45mph, put the trans in 2nd gear and progressively go into WOT. Take about 3 seconds to go from idle to WOT. This will take ae and shifting out of the equation.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  10. #30 Re: Tuning for a 3.5" pulley upgrade
    Banned
    CT
    Any progress on this issue?
  11. #31 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    Quote Originally Posted by SnowFlake View Post
    Today or later this week I will be getting another scan and re-flashing a lower base PE AFR. Right now, there is a lot of PE knock. I'm hoping to re-install the stock pulley and plugs over Christmas. If there happens to be a warm day, close to melting that is.
    Also wondering what you guys use for TCC lock and unlock settings in the normal and hot tables, 3rd and 4th.
  12. #32 Re: Tuning for a 3.5" pulley upgrade
    Banned
    CT
    When you say "PE knock" do you mean KR as soon as you enter PE at partial throttle? Or do you mean just WOT?
    These cars do weird things sometimes. I was tuning an N/A Gp a few weeks ago and the car had KR everywhere. He then did a full maintenance work up, added headers and 1 step colder plugs along with a new 180 t-stat. We were figuring it would handle a ton more timing... we were wrong. It still knocked badly.
    Went through the whole shpeal looking for false KR and all that and came up with nothing. In the end all I could do was send him on his way with a 12.8 AFR at about 19 degrees of timing. It made no sense at all especially considering I was getting away with 30 degrees of timing on my aunts NA GT that has no mods at all.
  13. #33 Re: Tuning for a 3.5" pulley upgrade
    hey, you weren't tuning my car by chance were you?
  14. #34 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    KR as soon as I enter PE, and anytime in PE. That leads one to believe PE AFR is too rich, but I am already leaner than stock by 0.4. To sum it up, I'm seeing about one degree of KR for every PSI of boost. My car is your friends car's bastard child.
    BTW, I was having a lot of sub-PE KR in the summertime, until I switched IFRs. Then, after you looked at my file, you put it back to stock. Somehow its been working very well sub-PE with the same settings that were killing me in the summer.
    Machines can be wierd.
    Thanks for the help.
  15. #35 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    OK, so I flashed a base PE of 12.2 and stock RPM-Time modifier table. Some improvement, but time will tell.
    Oh I bet you guys will give me **** if it was just my poor patience.
  16. #36 Re: Tuning for a 3.5" pulley upgrade
    Banned
    CT
    The only other thing I could think of is that your MAF is reading way less air than you are flowing causing a lean condition.
    Or the reverse and you're getting rich knock... but that doesn't usually come until sub 10.0 AFRs and your gas mileage would BLOW.
  17. #37 Re: Tuning for a 3.5" pulley upgrade
    Out West
    His MAF table looked okay, i've asked him for scans a couple times though lol.
    Whine with your Cheese?
  18. #38 Re: Tuning for a 3.5" pulley upgrade
    Out West
    Your base PE was a little too high for your mods. I wouldnt run higher than 12.0 base PE on a 3.5 pulley unless it was cammed. Lol.
  19. #39 Re: Tuning for a 3.5" pulley upgrade
    Banned
    CT
    I meant that his MAF is incorrectly reading the air. The tables in the PCM are fine.
  20. #40 Re: Tuning for a 3.5" pulley upgrade
    Out West
    Yeah, if he got me those scans i could see if the airflow isn't right for his mods.
  1. tuning for supercharger pulley
    By pureevilz28 in forum PCM Tuning
    Last Post: 09-23-2009, 06:05 PM
  2. PCM and Pulley upgrade
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 12:19 PM
  3. Found this on the LS1_LT1 site, "Most convenient LS4 tuning"
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 10-23-2008, 08:06 PM
