Thread: Tuning for a 3.5" pulley upgrade
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41 Re: Tuning for a 3.5" pulley upgrade
    Banned
    CT
    The only problem is I don't know how to "fix" that issue... I have ideas on how to bandaid it though.
    I'd like to see some WOT scans as well.
  2. #42 Re: Tuning for a 3.5" pulley upgrade
    GT Level Member jdmgtp's Avatar
    MI
    are you gonna post a scan or tune file? You have people try to help.
    help us help you...this is basic tuning stuff here
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  3. #43 Re: Tuning for a 3.5" pulley upgrade
    Out West
    Quote Originally Posted by jdmgtp View Post
    This.
    Whine with your Cheese?
  4. #44 Re: Tuning for a 3.5" pulley upgrade
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Stock pulley and plugs are back, and the car is running great. I'll be fine-tuning the AFR and timing and report back.
  5. #45 Re: Tuning for a 3.5" pulley upgrade
    Out West
    didn't even get scans. What gives, guy?
  6. #46 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    It hated the littler pulley. There was nothing to be done but fiddle with AFRs, which I exhausted. At the end of the day it didn't matter if the commanded ratio is + or - 0.3 with actual. I had tried 'em all.
  7. #47 Re: Tuning for a 3.5" pulley upgrade
    Banned
    CT
    Other than a MAF issue the pulley being too small seemed like the only reason why it would be acting up.
    Glad to hear it's running good now.
  8. #48 Re: Tuning for a 3.5" pulley upgrade
    MI
    Quote Originally Posted by mechguy View Post
    not sure what that's suppose to mean, guess we'll never know since you can't post a simple scan.
  9. #49 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    are you talking about? There are scans at the beginning of the thread. Furthermore, if you cannot understand tuning, don't play in the PCM section.
    You're posts vividly illustrate your lack of knowledge.
  10. #50 Re: Tuning for a 3.5" pulley upgrade
    MI
    Haha, ****ing joke. I gave you specific instructions for posting a DECENT scan so we could help you. I've tuned many many different combinations which I've gotten paid for and have nothing to prove to you buddy. Have fun with your stock pulley.
  11. #51 Re: Tuning for a 3.5" pulley upgrade
    And now this post shows a lack of respect.
    Not helpful at all.
  12. #52 Re: Tuning for a 3.5" pulley upgrade
    Florida
    Ok im getting sick of this thread... no progress...OP not trying what is suggested and helping with scans.
    these are my observations:
    -Fuel. if you refuse to run 93 or just dont have it available then you need to run less timing... or settle with overly rich AF
    -from the original scan i see your MAP is pretty high for not being in PE. it is possibly you have a vac leak somewhere.. and no your trims wont be off because you have done maf tunes with the leak which accounts for the leaking air.
    -it is very possible you just need more mods to run the pulley.
    and how can you sit there and accuse someone of a lack of tuning knowledge when you cant even figure out if your running too lean or rich and need to shoot in the dark with AFR's
    from the very beginning on 10-28-2011 the first reply i post what you need to do to correct 95% of tuning issues people see. if your not having luck many have offered to look at a full scan and bin file and help. the little screen shots of data you posted are not useful for correcting your issue. we need more data to get a better idea of what is happening. if your giving up fine. but like you said before your tired of people getting help and not posting the solution. do you want people to see your solution was just giving up?
  13. #53 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    You guys surprise me. I've run files from two members that have more experience tuning than all of us combined. I've also run the DHPV1.5 settings. Furthermore, I've used my mechanical inclination to tweak the tune when nothing else worked.
    I rest well knowing I did everything possible attempting to make the 3.5 pulley work.
    Stock pulley and fresh tune is now working great.
    There are very few settings to adjust in PE mode.
    Get real guys. Use the head you have.
    91 vs 94 octane makes a huge difference BTW. Also, no two engines are identical. I'm not too far ABSL and its cold here too.
  14. #54 Re: Tuning for a 3.5" pulley upgrade
    Florida
    -do you not have access to 93 octane?
    -ok you may have run files from experienced tuners... but if they didnt have access to good data then you wont get a good file.
    -DHP 1.5 settings are nothing but a starting ground if anyone were to just try and run them you would just be asking for problems.
    all we asked was for a good data log and bin so we could look things over for you. i just feel you threw in the towel too soon and didnt give us a chance to help.
    it may very well be that your engine just cant handle a 3.5 without more mods. either way more mods wont be a bad idea for it anyway... since your having issues tuning it, its best you build it so you can safely tune it yourself.
  15. #55 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    Quote Originally Posted by Z34Phoenix View Post
    I am not having any issues tuning the car. The issue was my gullibility to believe that the car MUST cooperate on that pulley. Tuning is not difficult.
    Stop asking about octane. I have stated numerously I will be running 91 fuel.
    I can CTRL-C CTRL-V the posted scan as many times as it requires for you to actually read it. Doesn't matter which road you step on the gas, you get the same results as posted.
    Not sure of a successor to scandepot.
    Post a tune file? You couldn't even embed video on the old GPF.
    Your attitude is easily detected even via interwebz.
  16. #56 Re: Tuning for a 3.5" pulley upgrade
    Banned
    CT
    I sent him an ultra safe tune that should have been fine... it still knocked. Pulley was too small for the octane/air where he's from. Simple fix for a simple issue.
    My headers/1.9 setup was pissed off a lot of the time on the 3.4 pulley and 93 octane in the winter.
  17. #57 Re: Tuning for a 3.5" pulley upgrade
    Florida
    my attitude? Yes i guess i do have "attitude" I am getting frustrated. YOU asked for help. we all suggested solutions and asked for more information to help YOU. I ask simple questions and you do not answer them. if you dont have access to 93 octane then say that. if you chose not to run 93 and want to run 91 say that. most run 93 on these cars so if you are trying to run a pulley with similar mods you will need more mods because you are running lower octane.
    as for a real scan... you could put it in a zip and upload it here or have it available to email. what you posted is like 10 seconds of data! come on man. you need more data then 10 seconds! its not always where the KR is that is the problem... but i forgot tuning is easy! it must be the car not wanting to cooperate on the pulley.
    ultimately it is your car. you are safer running a stock pulley anyway.
  18. #58 Re: Tuning for a 3.5" pulley upgrade
    Dec 2010
    Canada
    Curious to know what settings people are using for their TCC unlock/lock tables.
  19. #59 Re: Tuning for a 3.5" pulley upgrade
    Feb 2009
    flintnasty MI
    I like stock TCC tables myself... I have adjusted them for driver preference in the past. A bit earlier 3/4gear lockup points would net a tiny mpg increase.
  20. #60 Re: Tuning for a 3.5" pulley upgrade
    Topeka, KS
    Quote Originally Posted by SnowFlake View Post
    I can vouch for that. I think i need a bigger pulley for the winter as well. But i run 91 as the nearest place with 93 is 2 hours away.
  1. tuning for supercharger pulley
    By pureevilz28 in forum PCM Tuning
    Last Post: 09-23-2009, 06:05 PM
  2. PCM and Pulley upgrade
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 12:19 PM
  3. Found this on the LS1_LT1 site, "Most convenient LS4 tuning"
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 10-23-2008, 08:06 PM
