Thread: Need some serious help before i damage my car.
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 144
  1. #21 Re: Need some serious help before i damage my car.
    Quote Originally Posted by bobc455 View Post
    I'm afraid that if your coolant level is so low that you're losing it... maybe through an intake gasket (although I think your year came with metal gaskets from GM).
    You probably lost a significant amount of coolant for it to heat up so badly, if that's the problem. If your radiator and overflow is full, then you have a flow problem of some kind, and a flush might be a possible solution.
    Bob, we'd want to check that the temp gauge is actually correct first, before we assume an overheat situation right?
  2. #22 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    So the thermostat could be running to low and not letting the coolant flow?
  3. #23 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    He is saying you should scan it first to make sure it's not just the gauge that is the problem.
  4. #24 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    I also think everyone is also assuming you just purchased the car, is this correct?
    Jeff
  5. #25 Re: Need some serious help before i damage my car.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by blueguy View Post
    Anything north of 220* is too hot in my opinion.
    Sounds like it needs some work...either the t-stat is on its way to sticking...fans are crapping out...or the thing needs flushed. Either way, running that hot isn't normal.
    Any engine codes?
    Bingo Bango.
  6. #26 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Update: Bought pre-mixed coolant. uncapped radiator when cool, some coolant shot out as there was still pressure, filled with coolant to the top, filled the overflow bin, drove car for 30 minutes on my lunch break. thermostat stays 1/8th under the middle of the gauge, and when running it hard goes 1/8th over the middle. I am hoping this will last.
    Thoughts?
  7. #27 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    You did use the same coolant that was already in there correct? Keep an eye on the overflow bottle.\
    Jeff
  8. #28 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Quote Originally Posted by J57ltr View Post
    Jeff
    Yes, same coolant. i will check the bottle when i get home from work 5:00 P.M. PST
  9. #29 Re: Need some serious help before i damage my car.
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Exactly, factory gauges are known to be off of many cars. Often referred to as dummy gauges. On my truck its off. It quickly warms to right at 210 and stays there. I put a Dakota Digital Gauge on it. I also ran an autometer of some sort for a while to verify and the factory gauge shows 210 when the truck is running 199-220. It never moves. My truck has never gotten hot, but a few I know who tow very heavy up grades say it stays there and almost instantly goes from normal to 250 (red zone) once its overheating. No warning. I have heard of this with many other cars too. The GP's may not be much better.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  10. #30 Re: Need some serious help before i damage my car.
    Apr 2015
    Quote Originally Posted by industrialfish View Post
    Fans don't turn on until like 219 degrees, but still sounds like you are running hot. Maybe need a new thermostat and possible have air in the system. Temp sensor only measures coolant in the engine block, and if there is air trapped under the thermostat it won't open to circulate the cooler coolant from the radiator into the engine.
    There is a brass 7mm bleeder screw on the thermostat housing.
    Gonna have to disagree with you. My fans kick in well under the 210 mark. Not until the cars at like 185 mark for me.
  11. #31 Re: Need some serious help before i damage my car.
    id get a junk yard used coolant sensor and change it. its the sensor under the t stat in the lim.
    new ones are know to be bad new in the box. so either used, or find a delco.
    that temp sensor sends two signals, one to the dash gauge, the other to the pcm, the pcm tells the fans to come, and that part works you say cause the fans come on. and it dont seem like its really over heating. so the dash side of the sensor is broken likely.
    get a scanner on it, t app is cheap, it will tell your what the pcm says the temp is.
  12. #32 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by 01Grand PrixGT View Post
    You have an 01', 05' and later the fan does not come on until between 217-219*.
    Jeff
  13. #33 Re: Need some serious help before i damage my car.
    Apr 2015
    Jeff
    Oh really? Seems kind of dumb in my opinion.
  14. #34 Re: Need some serious help before i damage my car.
    true story..... as long as i had a 05 bin open, why not right?
  15. #35 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    Holy crap I hope I never hear the high speed fans. Thanks for the confirmation Scotty I haven't been able to pinpoint the exact turn on temp with my Torque App but that about sums it up.
    Jeff
  16. #36 Re: Need some serious help before i damage my car.
    Scott...thanks for posting the pic.
    That's exactly what I was saying, the fans are programmed for a temp. In the OP's first few posts, I was pretty sure I read that fans were kicking on at a higher temp than seemed correct. Hence my suggestion on checking temp.
    Now that you found pressure in a cool coolant system, that is also concerning. I would start by swapping the radiator cap.
  17. #37 Re: Need some serious help before i damage my car.
    Enfield, CT
    I would just changed the T-stat as well. Cheap and easy.
    Sent from my LG G3
  18. #38 Re: Need some serious help before i damage my car.
    Quote Originally Posted by HighOctaneRacing View Post
    I would just throw that effing T-stat across the street and bounce it off the pavement as well. Cheap and easy.
    Sent from my LG G3
    Fixed that up for ya
    I can check temp faster than a t stat...and I don't wait for the car to cool to do a stat
  19. #39 Re: Need some serious help before i damage my car.
    Buffalo
    Most of us at one time or another had the fan connector burn out Unplug it and see if it's burnt up inside
  20. #40 Re: Need some serious help before i damage my car.
    Enfield, CT
    Lol thanks!
    Sent from my LG G3
  1. Gen v damage
    By Anthony Smith in forum General Tech Discussion
    Last Post: 04-12-2013, 08:00 AM
  2. frame damage?
    By SDgrandprixGT in forum Off Topic Discussion
    Last Post: 09-14-2012, 01:19 AM
  3. How could I tell if there has been engine damage?
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-25-2010, 07:02 PM
  4. Whats the Damage?
    By MARKS99 in forum General Tech Discussion
    Last Post: 03-26-2009, 05:25 PM
