Thread: Need some serious help before i damage my car.
Page 8 of 8 FirstFirst ... 678
Results 141 to 144 of 144
  1. #141 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Quote Originally Posted by ScottyDoggs View Post
    fill it 3/4 the way up. then watch its level. hot and cold. it should rise and fall if your cap is working right.
    as coolant gets hot it expands and it needs to go some where, so it goes to the "over flow tank" convenient name right?
    when the engine cools off, it sucks the coolant back in from the over flow tank.
    ok got it. I should fill the whole bottle up to 3/4 the way? Over the line marker on the tank?
  2. #142 Re: Need some serious help before i damage my car.
    if you look close, theres a hot line, and a cold line on most over flow's. follow that. if its lower a day or to later that means the system was low and took in back in the engine.
    i like to just set it to the cold line when its cold, then check when its hot if it went up or not.
    then just judge it by the cold line first thing in the morning. a few mornings in a row. and if its the same your all set. if its low, fill it a bit to the line again.
  3. #143 Re: Need some serious help before i damage my car.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I fill mine like halfway up the bottle. Screw the fill lines, they're way too low to do anything. I just don't fill it up to the top.
  4. #144 Re: Need some serious help before i damage my car.
    Buffalo
    Wonder what the culprit was....
  1. Gen v damage
    By Anthony Smith in forum General Tech Discussion
    Last Post: 04-12-2013, 08:00 AM
  2. frame damage?
    By SDgrandprixGT in forum Off Topic Discussion
    Last Post: 09-14-2012, 01:19 AM
  3. How could I tell if there has been engine damage?
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-25-2010, 07:02 PM
  4. Whats the Damage?
    By MARKS99 in forum General Tech Discussion
    Last Post: 03-26-2009, 05:25 PM
