Thread: Need some serious help before i damage my car.
Results 1 to 20 of 144
  1. #1 Re: Need some serious help before i damage my car.
    Oct 2011
    Toledo, OH
    Fans don't turn on until like 219 degrees, but still sounds like you are running hot. Maybe need a new thermostat and possible have air in the system. Temp sensor only measures coolant in the engine block, and if there is air trapped under the thermostat it won't open to circulate the cooler coolant from the radiator into the engine.
    There is a brass 7mm bleeder screw on the thermostat housing.
    7"
  2. #2 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Do i just find the bleeder screw and undo it?
    Should i do it when the car has not been running?
    Thanks
  3. #3 Re: Need some serious help before i damage my car.
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Shawn Rollick View Post
    Thanks
    Open bleeder screw after car is hot, while running. Keep it open until you get a stream of coolant out the side hole instead of sputters of coolant/air. It's going to be hot so use a ratchet with extension etc. You'll probably have to do it again later. While you are doing it, take note if the fans are coming on too. If no coolant ever comes out, than you know the thermostat isn't working.
    7"
  4. #4 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Quote Originally Posted by industrialfish View Post
    I will try this tonight after work and will post an update. Thank you everyone.
  5. #5 Re: Need some serious help before i damage my car.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Gonna have to disagree with you. My fans kick in well under the 210 mark. Not until the cars at like 185 mark for me.
  6. #6 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by 01Grand PrixGT View Post
    You have an 01', 05' and later the fan does not come on until between 217-219*.
    Jeff
  7. #7 Re: Need some serious help before i damage my car.
    Apr 2015
    Quote Originally Posted by J57ltr View Post
    Jeff
    Oh really? Seems kind of dumb in my opinion.
  1. Gen v damage
    By Anthony Smith in forum General Tech Discussion
    Last Post: 04-12-2013, 08:00 AM
  2. frame damage?
    By SDgrandprixGT in forum Off Topic Discussion
    Last Post: 09-14-2012, 01:19 AM
  3. How could I tell if there has been engine damage?
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-25-2010, 07:02 PM
  4. Whats the Damage?
    By MARKS99 in forum General Tech Discussion
    Last Post: 03-26-2009, 05:25 PM
