Thread: No boost...
Results 1 to 20 of 20
  1. #1 No boost...
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Guess I've already inherited issues right off the bat. Drove the car on my lunch today, got up on it looked at my DIC boost gauge no boost...? Got on it a couple more times deff didn't feel any boost... The oil for the SC was just changed before I bought it. AC was off and have about 1/4 of gas. Any ideas? Thanks
  2. #2 Re: No boost...
    St. Louis
    Bad BBV? Vacuum leak?
  3. #3 Re: No boost...
    Sep 2015
    Seattle
    Bbv? Still new to the whole sc terms is that by pass valve?
  4. #4 Re: No boost...
    Sep 2015
    Seattle
    Popped the hood when I got home (26) miles from work, SC belt was hanging on fully intact the Idler pulley snapped off and is laying under the drive belt. Should be an easy fix. Anyone have a part number for it? It's the smooth one.
  5. #5 Re: No boost...
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Got to find out why you threw the belt first. Check all your pullies.
    GPONA #1 Cyber Bully
  6. #6 Re: No boost...
    the pulley seized up. sounds like #8 or 9 blew apart.
  7. #7 Re: No boost...
    Sep 2015
    Seattle
    It was #9. Bought the wrong one just now. Fml
  8. #8 Re: No boost...
    Sep 2015
    Seattle
    Duralast doesn't make one?
  9. #9 Re: No boost...
    they should, thats just whats on the list. try to get a metal one. they come both ways. plastic and metal. metal is a few bucks more.
  10. #10 Re: No boost...
    Sep 2015
    Seattle
    I found it, yeah I can't believe how cheap o the plastic ones are. What'd they think was going to happen. Smh.
  11. #11 Re: No boost...
    Sep 2015
    Seattle
    Mine is a torx head, does anyone know what size it is for sure T50…?
  12. #12 Re: No boost...
    Something like that, I forget the size but I think it's a T50.
  13. #13 Re: No boost...
    Sep 2015
    Seattle
    For anyone looking for part # or sizes, it was a T47 torx bit duralast pulley (metal) part # 231081 SC belt 660K6. Both at autozone.
  14. #14 Re: No boost...
    never heard of that size yet. pretty sure mines a t55. i know some are a 15 mm bolt.
    at least your all set now.
  15. #15 Re: No boost...
    The autozone pulleys suck just fyi, the bearings start to squeak after a year or so.
  16. #16 Re: No boost...
    he said he got a dorman @ autozone.
  17. #17 Re: No boost...
    Sep 2015
    Seattle
    Got a duralast lol guess I'll post back if it ever decides to squeak! Then I'll say damn that sob was right 😆😆
  18. #18 Re: No boost...
    Yeah the duralast dont last.
  19. #19 Re: No boost...
    FWIW I've talked drunkenly about and weighted the two options many times.
    Metal or plastic pulley to me doesn't matter IMO. It's all about the bearing inside. If that bearing starts to go, the pulley has an issue and you have an issue.
    Plastic pulley if the bearing locks up will stop and the belt will melt it fast. Likely resulting in you needing a belt and pulley.
    Metal pulley if the bearing locks up will stop and you will smoke the belt pretty fast. Resulting in you needing a belt and pulley.
    Moral of my rambling is.. which is actually better or worse? Notice the squeak and replace the pulley before you kill a belt.
  20. #20 Re: No boost...
    SE Level Member Cruisin38's Avatar
    Sep 2015
    Northern Illinois
    Weight could play a factor between metal and plastic.
    In terms of overall vehicle weight, and rotating assembly weight affecting revs etc.
    But just with a few idler pulleys, I imagine the difference to be negligible at best.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
