industrialfish
Fans don't turn on until like 219 degrees, but still sounds like you are running hot. Maybe need a new thermostat and possible have air in the system. Temp sensor only measures coolant in the engine block, and if there is air trapped under the thermostat it won't open to circulate the cooler coolant from the radiator into the engine.
There is a brass 7mm bleeder screw on the thermostat housing.
