Thread: Can a fuel pump from a GTP work on a GT?
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 106
  1. #61 Re: Can a fuel pump from a GTP work on a GT?
    SE Level Member keonmakesbeatz's Avatar
    Aug 2014
    Tested it with starting fluid . It blips to 2k rpm then just continues to crank . Pump is dead huh ? I haven't tried switching the lines, they are significantly different so I just guessed that I did it right .
  2. #62 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Someone told me it could be the mass air flow sensor
  3. #63 Re: Can a fuel pump from a GTP work on a GT?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Unplug the MAF and see if it starts, that would give you an answer if it was.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  4. #64 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Sent from BFE
    MAF sensor is good I guess . Did I mention that O' Reilly's deemed my battery bad ? I'm gonna try to jump it and also test the spark plugs
  5. #65 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Okay I'm a dummy . It wasnt spraying gas it was spraying air from the schrader valve *facepalm*
    I think my pump assembly is in wrong
  6. #66 Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Does anyone have a solution to the pump just pumping air?
  7. #67 Re: Can a fuel pump from a GTP work on a GT?
    Apr 2012
    Dayton, OH
    Might have got the lines wrong but i dont know anything about how our fuel systems work.
    Sent from BFE
    2012 F150 STX
  8. #68 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Sent from BFE
    When I tried to switch the lines, it was difficult to even move them around, also one line is bigger than the other one (exclude the vent) . The "F" fitting is smaller (im guessing it stands for feed) and the "R" (return?) is bigger . I put the big line on R and the small line on F
  9. #69 Re: Can a fuel pump from a GTP work on a GT?
    Apr 2012
    Dayton, OH
    How much gas did you put in the car? Or is in the car
    Sent from BFE
    2012 F150 STX
  10. #70 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Sent from BFE
    Not enough apparently . About 2 gallons . Could I pour gas into the assembly to try and get it to work ?
  11. #71 Re: Can a fuel pump from a GTP work on a GT?
    Apr 2012
    Dayton, OH
    Yeah fill the canister maybe put another 2 gallons in never know it could work
    Sent from BFE
    2012 F150 STX
  12. #72 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    This blue piece doesn't fit well around the pump . Though it did on the old one . I don't think it's created a good seal
    Here's the old one, i cant even hold the new one upright without the blue piece falling off
  13. #73 Re: Can a fuel pump from a GTP work on a GT?
    There should be a filterlike sock thing on the bottom of the pump and the bottom of the canister both.
    I think you are sucking air because there isn't enough fuel in the tank. Dump 10 gallons in and let us know.
  14. #74 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Both strainers are in . Now im having a hard time getting it back on . Whenever I have one part of the snap ring on, it seems like the other sides raise and are impossible to push down . This is so frustrating . I have to hold the pump down, put the ring on and hold the light at the same time
  15. #75 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Got it back in
  16. #76 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Still nothing . I'll fill it up and then see what happens
  17. #77 Re: Can a fuel pump from a GTP work on a GT?
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Seems like it should pick up with a gallon or I know cause I ran out of gas in my yard and put a gallon in and I drove it to the gas station
  18. #78 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    I know the lines aren't crossable,fat on fat,odd one in the middle,then smaller on end
  19. #79 Re: Can a fuel pump from a GTP work on a GT?
    check fuel pressure yet???
  20. #80 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    He said it was spraying air out,thought it was gas
  1. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  2. will fuel pump out of a sc car work ib a na car
    By geep in forum General Grand Prix Discussion
    Last Post: 11-28-2013, 01:38 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. GTP Fuel pump.. Will a GT pump work?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 01:19 AM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
