Thread: Can a fuel pump from a GTP work on a GT?
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 106
  1. #1 Can a fuel pump from a GTP work on a GT?
    SE Level Member keonmakesbeatz's Avatar
    Aug 2014
    Found one in a parts car on Craigslist. Just need to get my car running.
    Both cars are from the year 2000
  2. #2 Re: Can a fuel pump from a GTP work on a GT?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Yes the pumps are the same from the factory. GTP's don't have fancy pumps.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Quote Originally Posted by SnowTh1ef View Post
    YES! Thanks!
  4. #4 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2013
    Sandy, UT
    As long as they are the same year your fine. right around 00, 01 gt's and gtp's switched from metal to plastic tanks, the newer tanks use a venturi pump and older ones don't. But same year you should be fine unless I am forgetting something goofy.
  5. #5 Re: Can a fuel pump from a GTP work on a GT?
    The Boss Iceman6669's Avatar
    Jun 2011
    you are backwards... The older ones used Venturi. 97-first half of 2000 had venturi. Then second have of 2000-2008 used non-venturi pumps. PLUS IIRC the GTP pumps are dual speed pumps.
    2011 F-150 Yote powered
  6. #6 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2013
    Sandy, UT
    Hmm I am? Bc frosty and deckers cars are 01 and 04 and both have venturi pumps?
  7. #7 Re: Can a fuel pump from a GTP work on a GT?
    Jun 2011
    I have a 97 and it's Venturi.
  8. #8 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2013
    Sandy, UT
    I'm confused. Lol
  9. #9 Re: Can a fuel pump from a GTP work on a GT?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I'm pretty sure the GTP uses a different pump.
    GT: ACDELCO Part # MU1727
    GTP: ACDELCO Part # MU1785
    That's just what rock auto claims is the original equipment options for 2000, you might want to check a dealer catalog to be sure.
    Also, the GTP pump might fit on the GT and work just fine. Hopefully someone who has done it will chime in.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  10. #10 Re: Can a fuel pump from a GTP work on a GT?
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    The gtp is 2 speed,pretty sure on my 00 gtp the tank is metal,on the 03 se we have its 100% plastic,as far as I can see they look the same on gtp,gt,se by looking at the top,holes are same,not definite if they interchange but gtp is definate 2 speed cause when its going semi bad you can bend the terminal on the fuse for the pump out and plug it back in and works full speed
  11. #11 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Scotty may can help
  12. #12 Re: Can a fuel pump from a GTP work on a GT?
    I've done a bunch of swaps and a NA pump can easily fuel a SC engine. The opposite is also true.. an SC pump can fuel an NA motor, I run my SC pump in high speed mode all the time with my NA motor..... because the resistor blew a few years back.
  13. #13 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    So it won't consume anymore gas as usual billboost37?
  14. #14 Re: Can a fuel pump from a GTP work on a GT?
    Not sure I understand your question 94, please elaborate.
    An NA motor with pcm programming and fuel pressure regulator will keep things in check.
    An SC motor with the pump in high speed all the time plus regulator, you'll notice your fuel trims a bit off. But that's because when the programming is expecting you to be running in slow speed, you are in high.
  15. #15 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2013
    Sandy, UT
    Got it.. I have 2 NA original cars running SC setups. Thats why I was confused I guess. Didn't know about the two speed business.
  16. #16 Re: Can a fuel pump from a GTP work on a GT?
    The two speed thing was GM's sick and twisted way of causing GT's to win races against GTP's by disabling the fuel system when the resistor burned up.
  17. #17 Can a fuel pump from a GTP work on a GT?
    Aug 2014
    So I put the pump in the car, it wants to start (meaning i can hear slightly catching) but it just doesnt ? Did I buy a bad pump ?
    I'm thinking about just selling the car
  18. #18 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Was it new or used
  19. #19 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Used . He said it came from a running car and I believe him because he said i can come get a free one . There was no gas in the tank and I put roughly 2 gallons in the tank, do I need more ?
  20. #20 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    That's plenty I put a gallon in mine today,I've heard if they sit they can go bad,do you hear it hum?
  1. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  2. will fuel pump out of a sc car work ib a na car
    By geep in forum General Grand Prix Discussion
    Last Post: 11-28-2013, 01:38 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. GTP Fuel pump.. Will a GT pump work?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 01:19 AM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
