Thread: ball joints Press in or bolt on?
Results 1 to 20 of 20
  1. #1 ball joints Press in or bolt on?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I know this is a basic question, but as the cars still at my brothers house i havent been able to verify.
    I know my 97 gtp needs lower ball joints to pass inspection, what im not sure about is if they are simple bolt on ball joints, or press in.
    It looks like they are bolt ons in the images online but they could be stock photos. I have also read that it requres two wheen looking at the parts, does this mean there are two per wheel or 2 to do the front end?
    unrelated question these cars are boats from the factory as far as handling, i know that GMPP makes front and rear sway bars for the wbody cars, im not looking for huge handling out of this car, but i would like it to be on par (or preferably better) than my 06 fusion in terms of body roll and response, is this a reasonable expectation?
  2. #2 Re: ball joints Press in or bolt on?
    Horrible handling cars, for the most part.
    It's like trying to steer a boat in sand.
    Better tires, bigger sways front and rear (Dorman's work), with poly end links/bushings, strut braces front and rear...and of course, new LCA's/solid motor/trans mounts...and a stout spring/strut combo.
    As for the ball joints...just buy a set of new LCA's...they're cheap...ball joints are in there...and you don't have to press anything out. And the price isn't THAT much different either.
  3. #3 Re: ball joints Press in or bolt on?
    Balljoints are originally factory riveted in, replacements bolt in. The rivets suck to get out. You'll chisel the head and hit it with an air hammer.. they won't move. You'll end up drilling each one etc. Plus, likely the bushings in the control arms are also bad and for pretty cheap money, replace the entire control arm.
  4. #4 Re: ball joints Press in or bolt on?
    Buffalo
    Does energy suspension or prothane make poly bushings for our control arms?
    i just bought 2 new control arms for the 03 eclipse spyder and loaded them with energy suspension polys
    That's the way I would go when I re do my regal if they make them
  5. #5 Re: ball joints Press in or bolt on?
    Sep 2014
    Richmond Virginia
    hmm, its about a 60$ difference since i have to do both sides, the car also needs front rotors pads and tires, along with a window reg, (it was 800$ and it runs good) so i may just drill them out with my dads help since hes a tech, Im probably going used tires, ebay rotors and ive already got the regulator. Id be happy to hear any suggestions on cheap brakes, especially on the possibility of pulling the rotors and calipers off of a junkyard fbody
  6. #6 Re: ball joints Press in or bolt on?
    FBody's.
    Yup.
    Or CTSV/GT500 brakes.
    Or GP GXP brakes.
  7. #7 Re: ball joints Press in or bolt on?
    I cut an x into the head of the rivet with my air grinder then use my air hammer and they pop right out.
  8. #8 Re: ball joints Press in or bolt on?
    Feb 2010
    TN
    Bill's right bushings are most likely shot att bushing to price of a good set of joints it equal price of LCA's I got moogs off ebay $60. an arm, as fior cheap brakes and rotors you will end up with a ton of dust and again ebay got power slots 48 each and haw pads for 40 in fact the power slots were through J.C. Whitney you may just want to call them direct on the phone they give a discount not available on line. As for handling I hit the JY and took a sway bar off a police crusier its a lot bigger, then hit a caddie for a stb its bigger than the ones made for our cars and grabbed one for the trunk as well and I went with Assurance Goodyear rain tires car feels like its glued to road
  9. #9 Re: ball joints Press in or bolt on?
    Buffalo
    No one else thinks polys help ?
  10. #10 Re: ball joints Press in or bolt on?
    Jul 2013
    Richmond, VA
    Just did ball joints in mine. Prolly would have gone better if I had a better drill bit. I ground the heads on both sides flush and drilled after. Was a PIA. Remember that the nuts go on the bottom. If you put the bolt through the bottom and nut on the top the half shaft will bind on them.
  11. #11 Re: ball joints Press in or bolt on?
    Slutty Smutty... you are either full of manure or the luckiest man alive. I've yet to have one go that nice.
  12. #12 Re: ball joints Press in or bolt on?
    It was on a cutlass it that matters but the same principal
  13. #13 Re: ball joints Press in or bolt on?
    Bonneville, Regal, GP... they all want to keep their rivets. LMK when you do the next job...
  14. #14 Re: ball joints Press in or bolt on?
    It's easier to swap the lca so that's what I normally do lol
  15. #15 Re: ball joints Press in or bolt on?
    Sep 2014
    Richmond Virginia
    I think after seeing all the replies, im going to go for the LCA, then i shouldnt get stuck scratching my head if it doesnt go right. - thanks
    As far as handling i think im going to go with the sway bars, and braces to start off with. eventually ill probably go for the adjustable struts and lowering springs
    on a side note... I have 2 options im considering for license plates, "fne wine" and "fst boat"
  16. #16 Re: ball joints Press in or bolt on?
    Go with a standard off the shelf regular plate. That way you attract less attention. Trust me.. cops learn vanity plates and know all about boosted cars etc.
  17. #17 Re: ball joints Press in or bolt on?
    Sep 2014
    Richmond Virginia
    Good point... I am building this to be my sleeper anyway
  18. #18 Re: ball joints Press in or bolt on?
    I actually paid for United We Stand plates in MA. Looks a lot like a Veteran plate.
  19. #19 Re: ball joints Press in or bolt on?
    Feb 2010
    TN
    I have Mason plates on mine it has come in handy a time or two
  20. #20 Re: ball joints Press in or bolt on?
    I am pretty sure you can get Moog LCAs for less than $50 a pop on Rockauto, the Dormans are close to $40.
  1. 99 GTP Ball Joints
    By schwarry in forum Brakes/Suspension/Chassis
    Last Post: 04-03-2013, 02:44 PM
  2. Tie rods or ball joints
    By Cedric in forum Introductions/Noob Questions
    Last Post: 04-15-2011, 06:21 AM
  3. Replacing Ball Joints
    By 98GTPCALGARY in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 05:12 PM
  4. ball joints
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 05-07-2009, 07:45 AM
