Thread: should i fix this car or replace
Results 1 to 10 of 10
  1. #1 should i fix this car or replace
    Nov 2010
    washington
    My 2005 grand Prix Gt with 148,000 miles is self destructing.
    Since I got it 3 years ago it has occatinally thumped when starting out. Would happen 1 or two times a month. This recently got bad happening a couple times a trip sometimes it feels like you are being rear ended I'm thinking its a bad contoll selenoid on transmission expensive
    The power steering rack is leaking, I believe that is an expensive fix as well, rear brakes are due now, fronts are close
    It recently has started making a brake pedal vibration when pulling into parking spaces sometimes (I made a thread for that) that iI need to address now.
    I think replacing a PS rack is beyond my ability and the transmission selenoids I'm not sure are accessible with the Tranny in the car
    I don't want to put time and money into fixing the urgent break issue if the car needs 3000 grand of work
    The body/interior tires are excellent. Engine runs great but often takes 2 tries to start. I don't think I could get a nice clean car with new breaks and transmission for less than fixing this one so maybe its worth fixing
    Any thoughts?
  2. #2 Re: should i fix this car or replace
    Antioch, IL
    Its a used car........nuff said
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: should i fix this car or replace
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    You can go on ebay and get a new rack for $125, a transmission solenoid for $16 and 4 new rotors with pads front and rear for $150. Sounds like you have a warped rotor. As for the thumping on take off check motor mounts. You can do all this yourself. I spent 31 years as a petroleum structural engineer ( designing and building platforms and refineries ) but I have practically rebuilt my 2000 SE with the help of the people on this website. I wasn't a auto mechanic but I've become pretty good at it.
  4. #4 Re: should i fix this car or replace
    HUDSON
    If the body and interior are in great shape, defiantly fix the mechanicals to get it up to par.
  5. #5 Re: should i fix this car or replace
    Used car..sh*t breaks.. Do some maintenance and bam it's good to go.
    04 Comp G.
  6. #6 Re: should i fix this car or replace
    Dec 2012
    Where 4T65E's were born
    Try Lucas power steering stop leak before deciding to replace the rack, mine was leaking but that stuff stopped it
    Also it taking two tries to start...clean the throttle body and mass air flow sensor, both with the appropriate cleaners, and that issue should be solved.
    Sold.
  7. #7 Re: should i fix this car or replace
    Nov 2010
    washington
    I was worried more about the labor on the transmission and rack. The thumping definitely isn't motor mounts. I can often tell when its going to do it its like the engine reves and if I lift off the gas and then start againu it won't do it I'll look at it tomorrow and see if I can get access to the transmission selnoids with it still in the car
  8. #8 Re: should i fix this car or replace
    Omaha, NE
    Have you done anything to the car besides oil changes in the 3 years you have owned it?
  9. #9 Re: should i fix this car or replace
    Dec 2012
    You can access the transmission solenoids with it still in the car, its not as easy as just pulling a pan but its possible. I would look into the issue a bit more in case that's not the cause. Any codes?
    Sold.
  10. #10 Re: should i fix this car or replace
    Nov 2010
    washington
    Havnt messed with the car for a few weeks, it was rear ended (minor) but I didnt want to put any money into it until I knew that was going to get fixed.
    Only things ive done to the car in 3 years are oil changes, transmission service, battery, water pump and serpentine belt, air filters and turn signal bulbs. So not a lot of cost so far.
  1. Replace Everything
    By sweetsmootmc in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2013, 09:47 PM
  2. What should I replace?
    By loopy smurf in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-24-2013, 07:21 PM
  3. If I replace my bcm
    By 97GPJJ in forum Introductions/Noob Questions
    Last Post: 01-15-2013, 11:07 PM
  4. 3,1 to replace 3.8 in 98' GT?????
    By Dan Hammes in forum General Tech Discussion
    Last Post: 09-14-2012, 04:58 PM
  5. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
