Thread: What should I replace?
Results 1 to 8 of 8
  1. #1 What should I replace?
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Since I got the car about a year and a half ago, I'm losing oil. Not at an alarming rate, but I typically need to add a quart between oil changes. I am not seeing more than a drop or two of oil at a time on the garage floor under where I park my car, so it's not like it's gushing or anything, but I'm definitely leaking. My guess is valve cover gaskets. It looks like these are not a HUGE pain to replace, but is there anything else I should do (other than coolant elbows) if/when I do the VC gaskets? I'm not losing coolant and my oil is not all milk-shakey (whatever), so I'm guessing I don't need to mess with my UIM/LIM, and it's mostly likely just the VC gaskets. Is my thinking way off, or what?
  2. #2 Re: What should I replace?
    I live here. DirtDog's Avatar
    Jun 2012
    Could be the oil pressure sending unit. Look on passenger side and see if any oil is coming out at all. Valve cover gaskets are almost always a leaky problem.
  3. #3 Re: What should I replace?
    Pennsylvania, USA
    Even if your LIM gaskets aren't leaking, if they're not the aluminum ones, I'd do those ASAP. They worry me more than losing a bit of oil from VC gaskets.
  4. #4 Re: What should I replace?
    Could be your oil pan leaking.
    If the valve covers were really that bad to leave drops on the ground, your car would have caught fire and been burned to ground already.
    Also wouldn't hurt to replace the PCV valve, if its all gummed up you could be burning alot of the oil.
  5. #5 Re: What should I replace?
    Jan 2012
    Philadelphia
    Its always good to upgrade your LIM gaskets if there still the plastic ones I let mine go for a little to long and this is what it looked like witch is not good
    while i had it torn apart i replaced my spark plugs and VC gaskets made it alot easier
    I also upgraded to aluminum coolant elbows witch isnt a bad idea either
  6. #6 Re: What should I replace?
    Aug 2011
    Bucks County Pa
    Question
    When replacing the valve cover gaskets do you also need to replace the rubber gromments?
    George
    You don't have to but you should considering that it already comes with it when you buy the set.
    04 Comp G.
  8. #8 Re: What should I replace?
    they sell just vc gaskets w/o grommets.
    get the grommets , and get a set of felpro gaskets.
  1. If I replace my bcm
    By 97GPJJ in forum Introductions/Noob Questions
    Last Post: 01-15-2013, 11:07 PM
  2. 3,1 to replace 3.8 in 98' GT?????
    By Dan Hammes in forum General Tech Discussion
    Last Post: 09-14-2012, 04:58 PM
  3. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  4. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  5. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
