Thread: If I replace my bcm
Results 1 to 17 of 17
  1. #1 If I replace my bcm
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    I'm gonna replace my bcm cause Ive had a couple tell to so that my stuff inside my stops acting funny
    But I also read a thing on here that it could be my ignition and my key comes Right out so I thought I should replace that to
    So let me know if I shoul replace that ?
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: If I replace my bcm
    What?
    Can you try re-telling this problem in a complete sentence??
    We need to know your problem or else we can't say say what the real problem might be.
  3. #3 Re: If I replace my bcm
    Dec 2012
    grand rapids
    I'm gonna replace my bcm Ive been having some problems with electronic stuff inside my car and I'm also Gonna replace my blower resistor . I read on here that it could be my ignition but idk I was thinking about it last night and I realized that my key pops right out when car is running
    So what should I replace ?
    Should so A lil bit better
  4. #4 Re: If I replace my bcm
    Nov 2012
    Madison
    Quote Originally Posted by 97GPJJ View Post
    CHEAP Bosch 5.3 ABS REPAIR VW Passat Audi A4 A6 A8 S4
    Start with the repair, then move on from there. Not to sure what your gettin at.
  5. #5 Re: If I replace my bcm
    Sep 2011
    Copperas Cove, TEXAS
    I'm drunk and still couldn't read wut he said haha
    I live here. DirtDog's Avatar
    Jun 2012
    I think he's just gonna start replacing stuff just to replace it
    Sent from my DROID RAZR using Tapatalk 2
  7. #7 Re: If I replace my bcm
    Dec 2012
    grand rapids
    The reason why Ive started this thread is cause I'm having problems with the in side of my car and everything acting funny
    A guy told me that it could be my bcm
    Another guy told me it was the blower resistor cause he had one do the same thing an it was that
    A website and gpf said it could those 2 and my ignition
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Please be more specific if you want answers.
    A symptom list would be ideal.
    If your blower doesn't work on one or more speeds probably your resistor.
    If it doesnt work at all could be your igniton switch you'll need a multi meter to test the voltage at the switch. It involves removing the knee panel.
    Rarely do I see BCMs go bad in the pre 03 grand prixs. That would be the very last thing I'd replace..
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  9. #9 Re: If I replace my bcm
    Dec 2012
    grand rapids
    Quote Originally Posted by rperry435 View Post
    My car is a 97
    My car only works on high speed and when I turn it on my headlights turn off and my d.I.c turns off
    And now when I turn my fogs on my radio turns off
    Oct 2011
    MI
    Okay its simple. Your resistor is bad, 1 or more settings go bad..your high is a seperate relay built into the resistor thud why it works on just that setting... But your igniton switch is also bad.. Sounds like under load your accessory is dropping out. It's common and doesn't take too long to change either.
    I can assure you it is definitely not your bcm.
  11. #11 Re: If I replace my bcm
    Feb 2010
    TN
    Whew that was mess, I was waiting for someone get out there Captain Video decoder ring and figure out what he needed thanks rperry435 let me guess you are in the army in charge of encryption
    Oct 2011
    MI
    I would also like to note you aren't supposed to be able to pull out the key BUT that will not effect its operation...
    the ignition switch is the back portion of the key cylinder and when changing it the key portion won't be changed so even with the new ignition switch the key will still pull out. I just wouldn't worry about the key coming out. lol
  13. #13 Re: If I replace my bcm
    Dec 2012
    grand rapids
    Thanks alot everyone for the help
    Sorry about the confusing sh*t i put, i will make it more clear next time. doesnt help when i type on a smashed screen
  14. #14 Re: If I replace my bcm
    Dec 2012
    grand rapids
    It wasnt my resistor changed that and it still does the same thing
    Any other ideas ?
  15. #15 Re: If I replace my bcm
    Feb 2010
    TN
    I would be checking for a lose or bad ground wireor a negatie battry cable that may be internally bade
  16. #16 Re: If I replace my bcm
    Dec 2012
    grand rapids
    Doesn't the blower motor have a ground behind the radio ?
  17. #17 Re: If I replace my bcm
    Dec 2012
    grand rapids
    I just read this big ass article from sparkys Awnsers and everyone was having basically the same problem and it was the ignitions switch so thats my next thing imma do
  1. 3,1 to replace 3.8 in 98' GT?????
    By Dan Hammes in forum General Tech Discussion
    Last Post: 09-14-2012, 04:58 PM
  2. what all should i replace on suspension
    By Jonfisher84 in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2011, 09:17 AM
  3. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  4. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  5. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
