Finally! Got some pics of my AN-6 Fuel lines. Here they are....
Hope these explain it a little better!
So, why can't you use the spot where the flexible tubes meet the hard lines? Why cut all the way down there?
I guess I have a problem taking a dremel wheel to a gas filled line.
How do those fittings hold on to the smooth hard line?
no, my lines are the same size all the way through, i have them out.
i had a few other questions as well. what parts did you use for the lines that connect to the fuel rail itself, did you list those in your parts needed? also why do you need the 90 degree fitting? and why 3 XRP -6 AN straight female hose ends? why not 4?
your write up or how to seemed very vague to me, i guess i need more details
i bought all the stuff on your list minus 6 ft of hose because im not going back far, just removing the plastic fitted stuff, but i still wonder where are the fittings that i need for the rail. i found these - http://store.summitracing.com/partde...5&autoview=sku is this what i use?
