Thread: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
Results 1 to 20 of 27
  1. #1 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by Sabrewings View Post
    So, why can't you use the spot where the flexible tubes meet the hard lines? Why cut all the way down there?
    Because the lines are slightly smaller between the bottom of the car and there. Makes everything flow better.
    Looks slick by the way.
  2. #2 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Barksdale AFB, LA
    I guess I have a problem taking a dremel wheel to a gas filled line.
    How do those fittings hold on to the smooth hard line?
    2009 Subaru Impreza WRX STI
  3. #3 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by Street Wolf View Post
    no, my lines are the same size all the way through, i have them out.
    i had a few other questions as well. what parts did you use for the lines that connect to the fuel rail itself, did you list those in your parts needed? also why do you need the 90 degree fitting? and why 3 XRP -6 AN straight female hose ends? why not 4?
    your write up or how to seemed very vague to me, i guess i need more details
    i bought all the stuff on your list minus 6 ft of hose because im not going back far, just removing the plastic fitted stuff, but i still wonder where are the fittings that i need for the rail. i found these - http://store.summitracing.com/partde...5&autoview=sku is this what i use?
    COMP G
  1. Problems with AN fuel line setup, I have leaks, help please...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 05-19-2008, 01:29 PM
  2. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
  5. 04+ fuel return line
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 11:40 PM
