Thread: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
Results 1 to 20 of 27
  1. #1 Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Moore, Oklahoma
    This writeup on Custom AN Fuel Line Modification has been added to the How To section and can be found HERE.
    Shawn W. Larsen
  2. #2 Re: Custom AN Fuel Line setup for PRJ Fuel Rails...
    GTX Level Member 02BlueGT's Avatar
    Hoffman/Schaumburg, IL
    Nice, I am starting at the filter and going all the way to the rails, but I can't wait to see pics
    2002 GT...CAI, Headers, Special Eddition two-tone leather interior added, HUD added, 12" Brake Upgrade, ZZP strut tower bars, gmpp sway bars, poly motor mounts, -6an braided SS fuel hoses , Hptuned, Headers, Top Swaped, 50lb inj, E85, 3.4
    I've got Boost!! Top swap Quesions? Click Here
  3. #3 Re: Custom AN Fuel Line setup for PRJ Fuel Rails...
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    You're welcome for the help. It really is a piece of cake if you use those fittings.
  4. #4 Re: Custom AN Fuel Line setup for PRJ Fuel Rails...
    Yeah, I just got the first few in the mail, and ordered the last set.....
    Filter up on feed side and As far back as I have line for on the return(i bought 20 feet )
    Now I just need a camera so I can do a write up
  5. #5 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Moore, Oklahoma
    Finally! Got some pics of my AN-6 Fuel lines. Here they are....
    Hope these explain it a little better!
    Shawn W. Larsen
  6. #6 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Barksdale AFB, LA
    So, why can't you use the spot where the flexible tubes meet the hard lines? Why cut all the way down there?
    2009 Subaru Impreza WRX STI
  7. #7 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by Sabrewings View Post
    Because the lines are slightly smaller between the bottom of the car and there. Makes everything flow better.
    Looks slick by the way.
  8. #8 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Barksdale AFB, LA
    I guess I have a problem taking a dremel wheel to a gas filled line.
    How do those fittings hold on to the smooth hard line?
  9. #9 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by Street Wolf View Post
    no, my lines are the same size all the way through, i have them out.
    i had a few other questions as well. what parts did you use for the lines that connect to the fuel rail itself, did you list those in your parts needed? also why do you need the 90 degree fitting? and why 3 XRP -6 AN straight female hose ends? why not 4?
    your write up or how to seemed very vague to me, i guess i need more details
    i bought all the stuff on your list minus 6 ft of hose because im not going back far, just removing the plastic fitted stuff, but i still wonder where are the fittings that i need for the rail. i found these - http://store.summitracing.com/partde...5&autoview=sku is this what i use?
    COMP G
  10. #10 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Las Cruces, NM
    Compression fittings
  11. #11 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Barksdale AFB, LA
    Do you have to do anything else to the line besides cut it? No flaring? And... about the cutting... I take it that it is much more safe to drain the fuel from the lines first?
  12. #12 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    GTP Level Member David99GTP's Avatar
    Florida
    Well, after a wild goose chase to Autozone, NAPA and a pontiac Dealer here I am. Thanks for this write up!!!!!
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  13. #13 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Jan 2009
    Berthier, Qc, Canada
    I have a question about the Earl's hard line fitting, they seemed to be good to only 50 PSI, don't we have more than that at WOT ?
    Earl's Hard-Line AN Tube Fittings - JEGS
  14. #14 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by blackz34 View Post
    thats my concern. our fuel pressure is between 48-55 psi according to ALLDATA
    COMP G
  15. #15 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    No Dremel, pipe cutter
  16. #16 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Moore, Oklahoma
    No flaring the lines at all. I listed the PNs and pictures on the link above, heres the link, http://grandprixforums.net/fuel_line.php. Once you see them, you'll figure it out. Just make a nice, straight, clean cut and your good. As for draining the lines, I didn't. I just had a bucket handy for the excess fuel, thats it. Suck out the lines once you cut them, thats it really...
    Shawn W. Larsen
  17. #17 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Just to show anyone can do it, here are the pics from mine ((i just loaded em onto my PC today, but did the lines in early july)
    An connection at the Filter
    It goes with the other lines (return and evap)
    Almost looks like it should be there
    Last bracket before Firewall
    Hardline connector for the return, my 2.5 dp and gmpp sway in the background..and feed running along return
    Hardline adapter to 90* to stainless, was enough room for feed to make this turn without a fitting
    Comes up next to the steering rack and goes to the Drivers side of the brake booster
    If you can find it in this pic, you will see it curving around the brake booster
    Can you even find em in this pic?
    And they reapear from the top of the brake booster and under the Strut bar
    And they arrive at the Rail:bigthumb:
  18. #18 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Las Cruces, NM
    I've done 2 cars that way so far...not a single leak.
  19. #19 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Oklahoma
    As slowly as other things are moving on my car, maybe I can get this knocked out. What size line do I need? I know feed and return lines are different sizes, do I need to match that with the lines or can you use something like 3/8 - 5/16" SS lines and connectors?
  20. #20 Re: Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    Moore, Oklahoma
    Use AN-6 for both sides, thats what everyone does. I used AN-6 (3/8") on both sides. To make this work I used Earl's -6 AN Male to 3/8 in. Tube for one side, and the other I used Earl's -6 AN Male to 5/16 in. Tube for the other. Worked great!
    DON'T USE A TUBE NUT + SLEEVE, IT WILL LEAK MOST LIKELY!!!
    Read my instructions for more info...
    Shawn W. Larsen
  1. Problems with AN fuel line setup, I have leaks, help please...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 05-19-2008, 01:29 PM
  2. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
  5. 04+ fuel return line
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 11:40 PM
