also can someone take a pipc of the interior fuse block with the HVAC Control fuse (20a) should there be two pins the fuse plugs into. mine only has one terminal the fuse plugs into. could this be the reason im not getting mode actuator movement? but my HVAC Module has display and moves the temp actuators.
