Thread: Blend Door Actuator Replacement
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 90
Abrasive Blend Door Actuator... 10-09-2009, 08:30 PM
mfowler12 Re: Blend Door Actuator... 02-05-2010, 12:09 PM
mauer1 Re: Blend Door Actuator... 12-04-2010, 09:25 PM
FormulaW66 Re: Blend Door Actuator... 07-06-2011, 02:26 PM
meangene Re: Blend Door Actuator... 11-15-2011, 08:33 PM
scboy1969 Re: Blend Door Actuator... 04-04-2013, 02:56 PM
verlando Re: Blend Door Actuator... 04-28-2013, 09:55 PM
blueguy Re: Blend Door Actuator... 11-15-2011, 08:42 PM
meangene Re: Blend Door Actuator... 11-15-2011, 10:29 PM
lewethetiger73 Re: Blend Door Actuator... 11-16-2011, 12:40 PM
lewethetiger73 Re: Blend Door Actuator... 11-17-2011, 06:06 PM
copgtp Re: Blend Door Actuator... 11-17-2011, 06:24 PM
LilJoe Re: Blend Door Actuator... 11-18-2011, 02:16 PM
TomOfTarsus Re: Blend Door Actuator... 12-01-2011, 07:48 AM
Scottydoggs Re: Blend Door Actuator... 12-01-2011, 07:52 AM
TomOfTarsus Re: Blend Door Actuator... 12-01-2011, 09:34 AM
overdrive Re: Blend Door Actuator... 12-31-2011, 11:18 PM
kwakuzulu Re: Blend Door Actuator... 01-05-2012, 12:32 AM
Shannon Leigh Walker Re: Blend Door Actuator... 07-03-2012, 06:17 PM
GT03 Re: Blend Door Actuator... 07-04-2012, 12:47 PM
Great Biggie Re: Blend Door Actuator... 09-06-2012, 07:27 PM
Sam Smith Re: Blend Door Actuator... 10-30-2012, 10:37 PM
GT03 Re: Blend Door Actuator... 10-31-2012, 05:39 PM
coolio Re: Blend Door Actuator... 02-23-2013, 05:23 PM
Scottydoggs Re: Blend Door Actuator... 02-23-2013, 05:34 PM
TEK310 Re: Blend Door Actuator... 06-22-2013, 06:58 PM
TEK310 Re: Blend Door Actuator... 06-25-2013, 05:50 PM
coolio Re: Blend Door Actuator... 02-26-2013, 08:28 PM
peterg Re: Blend Door Actuator... 06-18-2013, 10:27 AM
Scottydoggs Re: Blend Door Actuator... 06-18-2013, 10:38 AM
peterg Re: Blend Door Actuator... 06-18-2013, 10:51 AM
Scottydoggs Re: Blend Door Actuator... 06-18-2013, 11:03 AM
peterg Re: Blend Door Actuator... 06-18-2013, 01:42 PM
Deeeepimpact Re: Blend Door Actuator... 06-20-2013, 11:03 PM
Scottydoggs Re: Blend Door Actuator... 06-21-2013, 12:06 AM
Scottydoggs Re: Blend Door Actuator... 06-22-2013, 07:01 PM
TEK310 Re: Blend Door Actuator... 06-22-2013, 07:23 PM
Scottydoggs Re: Blend Door Actuator... 06-22-2013, 07:36 PM
TEK310 Re: Blend Door Actuator... 06-23-2013, 04:49 PM
TEK310 Re: Blend Door Actuator... 06-23-2013, 06:11 PM
Exador Re: Blend Door Actuator... 07-09-2013, 02:33 PM
TEK310 Re: Blend Door Actuator... 06-23-2013, 05:05 PM
Scottydoggs Re: Blend Door Actuator... 06-23-2013, 05:44 PM
Scottydoggs Re: Blend Door Actuator... 06-23-2013, 06:26 PM
TEK310 Re: Blend Door Actuator... 06-23-2013, 06:32 PM
Scottydoggs Re: Blend Door Actuator... 06-25-2013, 06:03 PM
TEK310 Re: Blend Door Actuator... 06-25-2013, 06:30 PM
02GPinNY Re: Blend Door Actuator... 06-25-2013, 08:10 PM
GT03 Re: Blend Door Actuator... 06-26-2013, 09:01 AM
02GPinNY Re: Blend Door Actuator... 06-26-2013, 09:40 AM
TEK310 Re: Blend Door Actuator... 06-25-2013, 08:36 PM
02GPinNY Re: Blend Door Actuator... 06-26-2013, 06:33 AM
Scottydoggs Re: Blend Door Actuator... 06-26-2013, 09:49 AM
02GPinNY Re: Blend Door Actuator... 06-26-2013, 10:41 AM
Scottydoggs Re: Blend Door Actuator... 06-26-2013, 10:44 AM
02GPinNY Re: Blend Door Actuator... 06-26-2013, 05:01 PM
02GPinNY Re: Blend Door Actuator... 06-27-2013, 07:17 AM
GT03 Re: Blend Door Actuator... 06-27-2013, 08:15 AM
02GPinNY Re: Blend Door Actuator... 06-27-2013, 08:26 AM
Scottydoggs Re: Blend Door Actuator... 06-27-2013, 08:57 AM
GT03 Re: Blend Door Actuator... 06-28-2013, 09:15 AM
02GPinNY Re: Blend Door Actuator... 06-28-2013, 12:49 PM
TEK310 Re: Blend Door Actuator... 06-29-2013, 01:52 PM
Kscottm Re: Blend Door Actuator... 07-16-2014, 03:13 AM
appinboy Re: Blend Door Actuator... 06-20-2016, 09:44 AM
GTP in RTP Re: Blend Door Actuator... 08-01-2017, 10:00 PM
1996pontiac Re: Blend Door Actuator... 10-14-2014, 07:56 AM
mcmxgateman Re: Blend Door Actuator... 10-24-2014, 05:40 PM
Logan541 Re: Blend Door Actuator... 10-14-2014, 11:18 AM
Scottydoggs Re: Blend Door Actuator... 10-24-2014, 05:45 PM
Centauri Re: Blend Door Actuator... 04-19-2015, 11:52 PM
TexasTanker19kilo20 Re: Blend Door Actuator... 04-20-2015, 12:06 AM
Scottydoggs Re: Blend Door Actuator... 04-20-2015, 05:13 AM
appinboy Re: Blend Door Actuator... 06-20-2016, 10:01 AM
chris99gtp Re: Blend Door Actuator... 04-20-2015, 12:18 PM
Centauri Re: Blend Door Actuator... 04-25-2015, 02:54 PM
Scottydoggs Re: Blend Door Actuator... 04-25-2015, 02:56 PM
HighOctaneRacing Re: Blend Door Actuator... 04-25-2015, 09:29 PM
appinboy Re: Blend Door Actuator... 06-20-2016, 09:14 AM
Scottydoggs Re: Blend Door Actuator... 06-20-2016, 09:21 AM
appinboy Re: Blend Door Actuator... 06-20-2016, 12:29 PM
SomeDudeAtHome Re: Blend Door Actuator... 07-06-2016, 03:31 PM
Brick on Wheels Re: Blend Door Actuator... 06-08-2017, 07:53 PM
Scottydoggs Re: Blend Door Actuator... 06-08-2017, 08:03 PM
Brick on Wheels Re: Blend Door Actuator... 06-09-2017, 10:59 AM
Scottydoggs Re: Blend Door Actuator... 06-09-2017, 03:41 PM
GTP in RTP Re: Blend Door Actuator... 06-22-2017, 07:57 PM
Scottydoggs Re: Blend Door Actuator... 08-01-2017, 10:03 PM
GTP in RTP Re: Blend Door Actuator... 08-01-2017, 10:09 PM
Scottydoggs Re: Blend Door Actuator... 08-02-2017, 04:59 AM
  1. #1 Blend Door Actuator Replacement
    Odessa, MO
    Temperature Actuator Replacement LH
    Removal Procedure
    1.Remove the left instrument panel insulator (this is the carpeted cardboard piece above the brake pedal that connects to the knee bolster)
    2.Remove the knee bolster (this is the pad below the steering column)
    3.Remove the steering column filler (this is the metal piece behind the knee bolter, under the steering colum) (4 larger bolts, and I think 2 smaller ones)
    4.Disconnect the electrical connector from the temperature actuator.
    5.Remove the HVAC Con (HVAC Control) MiniFuse #27 from the IP electrical center.
    6.Remove the mounting bolts from the temperature actuator.
    7.Remove the temperature actuator.
    Installation Procedure
    1.Position the temperature actuator, then align the slots in the electric actuator driver to the flats on the temperature valve shaft.
    2.Slide the electric actuator driver onto the shaft, while aligning the actuator locating hole to the forward alignment pin on the HVAC module case. The actuator driver should completely seat onto the temperature valve shaft and the mounting holes should be flush with the mounting bosses on the HVAC module case.
    3.Install the mounting bolts to the temperature actuator.
    Tighten the temperature actuator bolts to 1.5 N·m (13 lb in).
    4.Connect the electrical connector to the temperature valve electric actuator.
    5.Install the knee bolster.
    6.Install the left instrument panel insulator.
    7.Install the HVAC Con (HVAC Control) MiniFuse #27 from the IP electrical center.
    Temperature Actuator Replacement RH
    Removal Procedure
    1. Remove the right instrument panel insulator. (The carpeted cardboard piece below the glovebox)
    2. Remove the instrument panel compartment. (glovebox)
    3. Disconnect the electrical connector from the temperature actuator.
    4. Remove the HVAC Con (HVAC Control) MiniFuse #27 from the IP electrical center.
    5. Remove the bolts retaining the temperature actuator.
    6. Remove the temperature actuator.
    1. Position the temperature actuator, then align the slots in the electric actuator driver to the flats on the temperature valve shaft.
    2. Slide the temperature actuator driver onto the shaft, while aligning the actuator locating holes to the forward alignment pin on the HVAC module case. The actuator driver should completely seat onto the temperature valve shaft and the mounting holes should be flush with the mounting bosses on the HVAC module case.
    3. Install the bolts to the temperature actuator. Tighten
    4. Connect the electrical connector to the temperature actuator.
    5. Install the instrument panel compartment.
    6. Install the right instrument panel insulator.
    7. Install the HVAC Con (HVAC Control) MiniFuse #27 from the IP electrical center.
  2. #2 Re: Blend Door Actuator Replacement
    Feb 2010
    Oklahoma
    Excellent writeup. I just have a question though before I go through this trouble.
    My wife's car, 2005 GP v6 (non-s/c), has a heater blowing cold air. We've done two complete radiator flushes. I added the green mixture instead of DexCool the second time around. I've replaced the thermostat and have checked all of the hoses for leaks. The hoses going to and from the heater core are very hot. When flushing the radiator, both times, I flushed out the heater core as well. Once I do a radiator flush, the heater works perfectly. About a month later, the issue comes back.
    Do you think this fix my problem?
    Last edited by matt5112; 11-16-2011 at 12:38 AM. Reason: no need to quote the entire post
  3. #3 Re: Blend Door Actuator Replacement
    Dec 2010
    wisconsin
    Thanks for the information it was a great help. It turns out my drivers side actuator was bad. It's a pain to get to but following your directions helped. Just so everyone knows, I have manual dual control. While the passenger side was fine it only blew luck warm air. It appear the drivers side is dominate. Once it was replaced the heat was like new. Thanks again.
  4. #4 Re: Blend Door Actuator Replacement
    Daytona Beach FL
    Nice write up!!! Just what I was looking for. Seems lots of other people are looking for this too this post will bump it up.
    2001 Grand Prix GTP - K&N CAI, Everything else stock
    1995 Formula Firebird - Too Many Mods to list
    www.formulaw66.cz28.com
  5. #5 Re: Blend Door Actuator Replacement
    Nov 2011
    Wichita
    Could you please post instructions for a single climate control system?
    Both Heater core hoses are hot, so I assume this is the problem. When temp is set to hot, flow is low and lukewarm, when I switch temperature setting to cold, flow increases and turns cold. Does this seem like a Blend Door Actuator problem?
    Thank you.
  6. #6 Re: Blend Door Actuator Replacement
    Apr 2013
    Illinois
    Quote Originally Posted by meangene View Post
    Thank you.
    Meangene, did you get this fixed and what was done? I have the exact same issue.
  7. #7 Re: Blend Door Actuator Replacement
    Aug 2012
    Washington State
    Wow, this operation seems MAJOR. Wonder what the auto repair shops charge where they use that guy who has the small hands.
    I have a 1992 Grand Prix that's always been a great car until we brought it out of storage. Suddenly, the heater works (warm air good) and fans work (range of speeds 1 thru 4 also good) and the Off switch works in terms of shutting off the fans but the problem is that it doesn't matter if I push the button for 'heat', 'vent', or 'defrost', etc; the air is pretty well split between the floor and the windshield and never goes full floor, full vent, full defrost, etc. And worst part now, the AC doesn't work either.
    Here's a picture of the control: http://home.nctv.com/ajns/92GrandPrixHeaterControl.jpg
    I have air blowing through the heater (at bottom floor board area) and defrost ducts at the same time but haven't been able to get the heat through the dash 'vent' locations and have been advised that the "blend door actuator" is probably the reason. Is there a way to 'cheat' the system and run a work around to get the AC compressor to work without going through a major job of tearing into the dash (and then risk it being something else anyway... ) ?
    TIA
  8. #8 Re: Blend Door Actuator Replacement
    ^^Yup.
    Just had that issue.
    Put in a new blend door on the driver's side...issue, fixed.
  9. #9 Re: Blend Door Actuator Replacement
    Nov 2011
    Wichita
    OK, I found where the actuator was. It is actually on the RH side on my GP.
    I took the actuator off, and manually turned the valve all of the way to the warm side, and the air is still luke warm.
    I re-checked the heater-core hoses, and one is appreciably hotter than the other. Car must not have been fully warmed up before when I checked. Clogged heater core?
  10. #10 Re: Blend Door Actuator Replacement
    SE Level Member lewethetiger73's Avatar
    Oct 2011
    mukwonago wi
    Sounds like my issues....
  11. #11 Re: Blend Door Actuator Replacement
    Oct 2011
    mukwonago wi
    Is there a way to test the actuators?
  12. #12 Re: Blend Door Actuator Replacement
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Quote Originally Posted by lewethetiger73 View Post
    What I usually do is try and swap them out with eachother, see which ones work and which don't. I also have a few extras lying around that i use to see if the actuator is the problem or not.
  13. #13 Re: Blend Door Actuator Replacement
    SE Level Member LilJoe's Avatar
    Nov 2010
    Mariposa
    i have same issues first some idiot toke out the fuse for the hvac put 1 in started working than a few weeks later started messing up and than i started hearing this werid ticking noise when the a/c was off than found a alil hole in a vac line replaced that it blew faster but still got that same problem
    1998GTP
  14. #14 Re: Blend Door Actuator Replacement
    SE Level Member TomOfTarsus's Avatar
    Nov 2009
    near Pittsburgh, PA
    Is there a write-up for the actuator or linkage that connects to the defrost/dash/floorboard selector switch? Mine is broke and I've been all around looking for some tips. Home from work today because I couldn't see to drive!
    Thanks,
    Tom
  15. #15 Re: Blend Door Actuator Replacement
    that part works on vacuum, check for a leak under the hood, the small tube that runs up the pass side fender to the fire wall sometimes snaps.
    the actuators only work the blend door for hot or cold air.
  16. #16 Re: Blend Door Actuator Replacement
    Nov 2009
    near Pittsburgh, PA
    Thanks!
    Well, as luck would have it, my problem actually was the knob itself that had broken. But wow, I was looking under the dash as to how to get the front of the dash off, and it looks like (from what I've seen here as well), you have to start at the center console and work your way forward? Man, I'm glad the stock radio was good enough for me!
    So. "vice grip" knob hanging off the dash, it's off I go!
    Thanks again,
    Tom
  17. #17 Re: Blend Door Actuator Replacement
    Nov 2010
    Hannibal, MO
    We have a 2003 GT w/dual climate controls. Could someone please tell me where the actuator is? Thanks. Dan.
  18. #18 Re: Blend Door Actuator Replacement
    Aug 2011
    Mesa, Az
    I have a 04 with the basic system. Does this write up apply? I have no heat, but get a clicking noise when I unlock the car, or its been parked for a while. I think a gear is broken in the Hvac actuator or something.
  19. #19 Re: Blend Door Actuator Replacement
    Jul 2012
    Illinois
    I have a 2004 Prix GTP...she does NOT have dual climate control. A year ago in the winter, the blower motor went out and we had no heat. We got that fixed and now the blower works very well but now there's no A/C! Today as I was complaining about it since it was only about 104' outside, my son said that on the passenger side, he had cool air blowing out *it wasn't as cool as it should be* whereas I, on the driver side had lukewarm to warm air blowing out. I was told this was a problem with the actuator, which according to what I'm seeing on here, that's more than likely what it is.
    My questions are: 1-Is there only ONE actuator for each side of the car or only ONE for the entire car? 2-Is there anyway to be 100% sure that this is what it truly is? 3-Is this something that can easily be done by me?
    The last question is due to wanting to save the money and mainly because I've never really had to take my car in anywhere, my husband was always the one to do it. The first time my car was ever taken in elsewhere was for the blower motor. My husband had cancer and wasn't able to do it himself but he passed away on May 1st, a month shy of turning 46 and now he's no longer here to do things like this for me, so if at all possible, to save money, I would prefer to be able to do whatever I can myself. Thanks for any input.
  20. #20 Re: Blend Door Actuator Replacement
    Jun 2011
    N. Ga Mtns
    If you have the two manual temp control sliders you have two actuators. My '03 GT is suffering the exact same symptoms as yours, funny how that popped up with the current heat wave.
    I haven't dug into it yet, but it doesn't look too hard.
    Most likely that's the problem, judging by how many people have had this same complaint, but you won't know 100% until you change it. I've found Rock Auto to be low cost and fast parts delivery for my GT.
    Good luck!
    UPDATE: Access to the left actuator is somewhat a PITA, OK if you were a car stereo installer in your youth.
    Turns out my actuator is OK, it moves the blend door the full range that the door can move. The door itself feels OK the full range of motion, and sounds like it goes all the way to closing off either heat or cool ports.
    I still have a large temp difference from driver to passenger side and poor cooling. With the A/C set to Max, temp sliders set to cold, fan speed set to 3, engine at idle speed, outdoor temp of 88º, I have 92º on the driver center outlet and 74º on passenger center outlet.
    I'll have to check refrigerant pressure for the overall cooling issue, but why the big difference between sides when the blend door operation seems OK? Is there a good online parts breakdown of the heater assembly? Has anyone dug into their heater that far that could share some insight? Are the blend doors prone to breaking off part of the flap?
    UPDATE 2: Refrigerant was low, recharged, now the with the same parameters as above I have 38º from drivers center outlet and 40º from the passenger center outlet. Why the drivers side is now cooler than the passenger side is a mystery. I'm just happy it's cold air that's coming out for cheap! Two 12 oz cans did it.
    So what seemed to be a blend door problem, wasn't.
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
