Thread: Blend Door Actuator Replacement
Results 1 to 20 of 90
  1. #1 Re: Blend Door Actuator Replacement
    you can pop the d/s actuator off and then turn the knob by hand, if you can make it blow cold manually the actuator is bad.
    if its still warm, the system is low for sure. but you got the a/c gauges so you can also test the line pressures.
    and its been f ing hot here the last few days.
    not sure what the difference its either, you got lkq parts right down the road from you, go ask them for a used one. LKQ Hunts Point Auto Parts
  2. #2 Re: Blend Door Actuator Replacement
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Thanks Scotty! I'm so glad my work station is directly across from the AC Unit here at the lumber yard. I'll install the freon first and if it's still hot I'll try and manually close the door. I saw only one video from a 98' Chevy Something, and it didn't look so bad to reach from under the driver's side dash.
    2002 GT Red, Stock, Work In Progress..........
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
