Thread: Blend Door Actuator Replacement
Results 1 to 20 of 90
  1. #1 Re: Blend Door Actuator Replacement
    Jun 2011
    N. Ga Mtns
    Quote Originally Posted by 02GPinNY View Post
    Right now I'm having an issue with my 02' GP GT. The passenger side blows cold air on AC but the driver's side blows hot. Does anyone know the part number for that Actuator Motor. I'm assuming it needs to be replaced. Thanks. I'm tired of driving with the driver's side vents shut and turning all the passenger side vents my direction. It's getting too hot these days for that kind of nonsense. I'd rather sweat my azz off for one day repairing it.
    I had the exact same symptoms on my '03 GT, turns out it was the refrigerant level was low, not the actuators. Worth a check, it's an easy fix if that's the problem.
    If you need an actuator, RockAuto has the best price by far.
    Good luck!
  2. #2 Re: Blend Door Actuator Replacement
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by GT03 View Post
    Good luck!
    Thanks! I actually have a recharge system in the trunk right now. I'll dump it in when I get home to see what happens. I will say that the passenger side doesn't blow as cold as my 86' Olds did so you may be right. I still don't know how to differentiate between Auto AC and Manual AC systems??
    2002 GT Red, Stock, Work In Progress..........
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
