Thread: Blend Door Actuator Replacement
Results 1 to 20 of 90
  1. #1 Re: Blend Door Actuator Replacement
    first post of this thread is the how too to change them. drivers side is a bit tight. but very doable. i wear size 3 x gloves, so i got large hands, yes i bled a little, but i got em in and out. more then once sadly lol
  2. #2 Re: Blend Door Actuator Replacement
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Well, thanks Scotty. I dodged a bullet with this one. I got home from work and attached the can of AC Pro, set the AC to Max, and let her rip. It was definitely low of juice. After 5 minutes the can was empty and all the vents were now blowing COLD ICY AIR!!! Whew! No taking apart the dash for me thank God! Also, I noticed as you had said, my temp gauge went down with the AC on Max too. Thanks everyone for all the help. No more sweating for me in the GP!
    2002 GT Red, Stock, Work In Progress..........
  3. #3 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    I guess I spoke too soon! I get downstairs this morning and hit the AC Control and the passenger side is ice cold but the driver's is still running warmer. Big difference though from before, just not as cold as the other side. So I guess I'll be under the dash this weekend!
  4. #4 Re: Blend Door Actuator Replacement
    Jun 2011
    N. Ga Mtns
    Quote Originally Posted by 02GPinNY View Post
    Was it up to the proper charge pressure for the ambient temp? When I got mine to spec, the drivers side ended up slightly cooler than the passenger side, go figure...
    From Msg #18 "UPDATE 2: Refrigerant was low, recharged, now the with the same parameters as above I have 38º from drivers center outlet and 40º from the passenger center outlet. Why the drivers side is now cooler than the passenger side is a mystery. I'm just happy it's cold air that's coming out for cheap! Two 12 oz cans did it.
    So what seemed to be a blend door problem, wasn't."
  5. #5 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by GT03 View Post
    Yep, I set the ambient temp gauge and it was at the proper charge, but at the "low end" of the spectrum. The can was empty at that point. At the instant I finished, both sides were blowing cold with the passenger side just a smidgen colder. I never sat for an extended period of time though. I just shut it off and went upstairs. I may need another can to get to the higher end of the scale.
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
