I hope someone could help me with problem. I have a 99 GTP with the dual climate digital a/c and it will not blow out any air. You turn the temp to 60 and you here everything clicking and moving but no air at all is coming out at all, not even the sound of air running. BUT still hear everything turning and clicking when cycling through the modes or turning the a/c from auto and increasing fan speeds.. BUT NO AIR BLOWING OR SOUND OF AIR at all...
I tried holding both buttons down doing the diagnostic and i got -115 at the -0 prompt. which would lead me to believe there was a actuator problem.. hit the auto button and reset the system and haven't been able to get any codes back. I tried removing the HVAC fuse for 1 minute and then replacing it then not running system for a minute.. still no glory. Could a bad LH Actuator cause A/C not to blow ANY air? or cause the blower not to turn on?
Anyone have any other suggestions? my next step is trying to get at the blower resistor plug and trying to see if i can get any voltage with a multimeter?? am I heading in the right direction? ANY help would be appreciated.
ARE my colors for the wires correct?
Wires to Blower Motor:
Purple: ??
Black: ??
Wires to Blower Control Module:
Orange: ??
Black: ??
Gray:??
THANKS!
