Thread: Question about how much boost I'm running?
Results 1 to 20 of 115
  1. #1 Re: Question about how much boost I'm running?
    Kemmerer, Wyoming
    Quote Originally Posted by Tonkin2000GT View Post
    Yea I'm not really worried about the map I have a mechanical boost gauge hooked up. Zzp has it reving to about 6400 right now they said it's benificial to rev higher but not till i put heavier valve springs in. My heads are ported already and they said 7.00 push rods will get me to the happy place with a ls7 lifter stock is 7.05.
    a mechanical boost gauge and a map sensor are totally different. the pcm is going to use the map sensor to operate the engine. the boost gauge only shows you what is happening inside the engine. you really need to study how an engine works to understand why the different length pushrods are not necessary unless you take measurements and see that you need them. LS7 lifters are about the same length as oem lifters so most people don't change pushrods.
    it really seems that you believe everything zzp says without any question. you need to learn more about engines because everything zzp says may be true in some cases, but not entirely.
  2. #2 Re: Question about how much boost I'm running?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by SgtMarshal View Post
    Yea I understand how an engine works I built this myself.... I just thought the boost seemed a little low. Ls7 lifters have a tighter range then stock so you need to find the happy medium. Yes I do believe zzp haven't had a problem yet why wouldn't I go with them?????
  3. #3 Re: Question about how much boost I'm running?
    lord help you man. zzp sucks a dick on there info, most of it is bull sh it just so you buy parts. its what they do, sell parts you know.
  1. running your got with no boost?
    By hollas13 in forum General Tech Discussion
    Last Post: 05-03-2014, 07:34 PM
  2. Running on full boost!!! AAAHH!!!
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2012, 04:13 PM
  3. car is running low boost and is throwing a p1646
    By sseigtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2012, 09:32 PM
  4. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  5. How many pounds of boost should I be running?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 01:36 PM
