These lights reset every time you turn the key to off. If they stay on, then you still have a problem.
Like many other members here, I have had my share of wheel hub issues. When you get a scanner with a code that indicates which wheel is the problem, check all of the wiring and connectors before replacing the hub. On 04+ cars in general, there are places where the wiring can stretch or rub and break, especially going to the front hubs. I've read about several cases where people have replaced front hubs only to have the light come back, and the fix ended up being a new wiring harness.
