My Advance uses one of the better Actron scanners too.
at your uncles shop. no one does it for free really. the software alone is a couple grand a year to keep the scanner up dated.
unless you have a newer car and your parts store has a higher end code scanner. it may, or may not scan for abs codes.
Doesn't the torque app scan the wheel speed sensors?
Yeah torque does but its real laggy and not the actual speed. Like when doing 40 it will show 22 or something. It may help if you locked in cruise and waited for it to level out to see if there is any variance, but I wouldn't trust it enough to change a hub out.
