Thread: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
Results 1 to 9 of 9
  1. #1 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    Feb 2014
    NJ
    Hi Guys,
    Original 98 GTP owner her. 100k miles, cherry condition. The car has absolutely gone to sh!t the last two weeks.
    coolant leak, replaced elbows - not it, replaced water pump - fixed it, resonator blew up - replaced that[/color]
    Now the car will not start.
    In the on position the dash gauge lights will not illuminate - the DIC flashes 0 for range/oil and the car cranks but will not start.
    Any comments/help much appreciated. TIA
  2. #2 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    I'd start by removing and cleaning the battery terminals and all grounds that you can see in the engine bay.
  3. #3 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    if not that stuff ^^^^ the starter took a crap. try hitting it with a hammer while the key is held to start. if it cranks the starter is bad for sure.
  4. #4 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    Feb 2014
    NJ
    Thanks for he suggestions...bat terminals are good...I cleaned the neg ground closest to the battery...made no diff
    as to the starter...the engine cranks real strong..it just won't start...the dash gauge lights not coming on leads me to think it is electrical.
    btw, batt is newish/good, ignition switch was changed out a few months ago
    pcm?
    fuses?
    harneses?
    cps?
    tia for any more leads
  5. #5 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    oh, miss read. you need to see whats missing, fuel or spark.
    theres a shrader valve on the fuel rail, take the cap off and push the pin in, gas should spray out. if it dont the fuel pump is bad.
    if you have fuel, take a plug wire off the coil and prop it like a inch over the coil above its socket, then crank the engine, a big blue spark should jump to the plug wire. no spark, no spark.
  6. #6 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    Check for spark and fuel.
  7. #7 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    Feb 2014
    NJ
    As luck would have it...it has been starting fine the last two days. I have to wait for it to act up and check spark/fuel.
    Thx again.
  8. #8 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    Jun 2015
    Clearwater, FL
    Check the electrical connections at the coil pack and relay box for signs of damage or corrosion. Maybe even the MAF sensor? I've learned that these cars can have starting issues with a dirty MAF or throttle body
  9. #9 Re: 98 GTP - No gauge lights - Crank but no Start Consition - Please help
    SE Level Member lizahart's Avatar
    Jul 2015
    Canada
    Checked the fuses box yet?
  1. Crank no start!
    By RobGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2014, 09:09 PM
  2. Crank but no start.. Help!
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 11:31 PM
  3. Crank but not start
    By Coldwaves in forum General Tech Discussion
    Last Post: 05-20-2013, 05:21 AM
  4. No crank, no lights, no start? One click thats it !
    By thegipper in forum General Tech Discussion
    Last Post: 11-26-2011, 01:52 AM
  5. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
