Thread: What 3 guages are most important to have?
Results 1 to 20 of 21
  1. #1 What 3 guages are most important to have?
    GT Level Member Hardonyomom's Avatar
    aurora
    Okay, so i just bought a 3 pod pillar and i need to pick some gauges to go in there.
    What would be the 3 best you would pick?
    I was thinking a wideband, an aeroforce , and a fuel pressure?
    2 aeroforce, and wideband?
    aeroforce, boost , and wideband?
    Which ones are most important?
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: What 3 guages are most important to have?
    if only using 3 id go 2 aeros and a wideband.
  3. #3 Re: What 3 guages are most important to have?
    Mar 2014
    Tucson
    What if budget only allows 1 aeroforce?
    1.) Aero
    2.) Wideband
    3.) ???
  4. #4 Re: What 3 guages are most important to have?
    Kemmerer, Wyoming
    or get 3 aeroforce gauges and an aeroforce wideband
  5. #5 Re: What 3 guages are most important to have?
    Kemmerer, Wyoming
    you can get an aeroforce wideband to work in conjunction with the aeroforce gauge. I'm not sure what to get for the other 2 holes, I just run 3 aeroforce's
  6. #6 Re: What 3 guages are most important to have?
    aurora
    I hear a lot of people don't really like aeroforce gauges because they can be hard to see or read while driving.
  7. #7 Re: What 3 guages are most important to have?
    Kemmerer, Wyoming
    the only time I have issues seeing or reading my aeroforce is when I have polarized sunglasses on.
  8. #8 Re: What 3 guages are most important to have?
    Nov 2011
    NY
    Volt, Boost, Oil
    No need to know fueling cause once tuned it's set anyways... KR scan is always good (aeroforce) but once tuned shouldn't be a problem unless something broke or maybe bad gas, lol.
    But volt, boost and oil can tell me something else is happening. And yeah, I'd probably hear it before I see it if oil pressure goes, but wth... Lol, that's my $.02
  9. #9 Re: What 3 guages are most important to have?
    1) aeroforce
    2) wideband
    3) gauge of your choice.
    Personally I just stick with a hud pod and just run the first two
    04 Comp G.
  10. #10 Re: What 3 guages are most important to have?
    The Boss Iceman6669's Avatar
    Jun 2011
    Boost
    AeroForce
    WideBand
    2011 F-150 Yote powered
  11. #11 Re: What 3 guages are most important to have?
    Apr 2012
    Goderich, Ontario
    I have 2 Aeroforce gauges and a vac/boost gauge.
    -Paul Walker
  12. #12 Re: What 3 guages are most important to have?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SgtMarshal View Post
    What year is your car, and how do you have your gauges setup?
    Quote Originally Posted by smoke14
    I think I'll be replacing my middle Aeroforce with a vac/boost gauge too.
    7"
  13. #13 Re: What 3 guages are most important to have?
    Kemmerer, Wyoming
    Quote Originally Posted by industrialfish View Post
    my car is a 2001 Grand Prix GTP. I have the aeroforce triple gauge setup with a pillar pod from zzp. I dont have the aeroforce wideband setup yet, but I am considering it as a next mod.
  14. #14 Re: What 3 guages are most important to have?
    oil pressure is the most important gauge you can have in your car and i didn't see it listed in this thread yet. shame on you people.
    a wideband is nice, but it's really only needed when you're tuning the car. after that it becomes a useless flashy light show gauge.
  15. #15 Re: What 3 guages are most important to have?
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    I run a boost, and two aeroforces. One of my aeroforce runs oil pressure, the other wideband.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  16. #16 Re: What 3 guages are most important to have?
    Oct 2011
    Toledo, OH
    You have all three running at the same time with no problems? How many parameters/refresh rate?
    Right now I have a triple installed, but only have 2 running. One boost/KR at fastest speed, the other cycles IAT/Coolant/Trans Temp at slowest refresh. Can't seem to get three to run reliably. If I replace one with a boost/vac then I can install my Aeroforce Oil Pressure kit on the fast refresh one.
    7"
  17. #17 Re: What 3 guages are most important to have?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Here's what I have.
    In my 3-gauge pillar pod:
    - Volts
    - Boost
    - Oil Pressure
    HUD Pod:
    - Aeroforce
    - Wideband
    I'd definitely say go with an Aeroforce, Wideband, and Oil Pressure.
  18. #18 Re: What 3 guages are most important to have?
    Aug 2011
    'Merica
    What's oik pressure?
  19. #19 Re: What 3 guages are most important to have?
    Jun 2011
    I don't know what you're talking about
  20. #20 Re: What 3 guages are most important to have?
    Aug 2011
    'Merica
    Ha!
  1. my first mod....and most important to me.
    By spider4 in forum Visual/Body Modifications
    Last Post: 12-24-2011, 01:03 AM
  2. Important I need hid help
    By Soviet in forum Audio, Security & Visual Electronics
    Last Post: 01-20-2011, 08:05 AM
  3. Guages
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2008, 11:43 AM
