if only using 3 id go 2 aeros and a wideband.
you can get an aeroforce wideband to work in conjunction with the aeroforce gauge. I'm not sure what to get for the other 2 holes, I just run 3 aeroforce's
You have all three running at the same time with no problems? How many parameters/refresh rate?
Right now I have a triple installed, but only have 2 running. One boost/KR at fastest speed, the other cycles IAT/Coolant/Trans Temp at slowest refresh. Can't seem to get three to run reliably. If I replace one with a boost/vac then I can install my Aeroforce Oil Pressure kit on the fast refresh one.
