Thread: Cam install questions
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 72
  1. #1 Cam install questions
    Dec 2013
    Rochester, NY
    Hey everyone. I've been searching around for answers on this stuff but I'm not really finding a straight answer. I've got an 05 gtp, and I'm planning an xp cam install. Here's the list of everything I'm doing:
    3 in zzp downpipe
    3.3 pulley
    Cam with modded retainers
    Zzp pushrods
    Rear sway bar
    Trailing arms
    Ss power log
    Plugs and wires
    What springs should I go with? Should I concerned about blowing anything? And would this be too much on stock heads? And can anyone think of anything else I should do?
  2. #2 Cam install questions
    Headers instead of the Plog/downpipe combo. If your going to do pushrods you might as well do lifters. That cam is fine with stock heads. I would go with 105 for springs. Remember to change the lim gasket (unless it's already aluminum), change the vc gasket and timing gasket I would also change the timing chain/dampener while your at it to either a stock replacement or upgrade it if you choose. For susp lowering it and also you can update the front and rear sway bar to either the GMPP or Comp G.
    04 Comp G.
  3. #3 Re: Cam install questions
    And more importantly you better have something to scan with before you chip a piston and also have someone who knows what they're doing to tune it
    04 Comp G.
  4. #4 Re: Cam install questions
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I agree with the above but don't waste your time and money on pushrods and lifters, put that money into headers or elsewhere.
  5. #5 Re: Cam install questions
    Pushrods are a waste unless for some reason you need them like if you had head work done or such Lifters can be replaced at a later time as well.
    04 Comp G.
  6. #6 Re: Cam install questions
    The Boss Iceman6669's Avatar
    Jun 2011
    If you do LS7 lifters you will need shorter pushrods, but otherwise leave stock pushrods. Also 90# springs are an option with XP cam.
    2011 F-150 Yote powered
  7. #7 Re: Cam install questions
    Seems to be a hit or miss on guys needing shorter pushrods w/ the LS lifters
    04 Comp G.
  8. #8 Re: Cam install questions
    Florida
    105# springs, new timing chain and new chain damper.
    New valve seals too.
    I would also go with headers over the plog/DP combo.
    Shouldn't be worried about any issues as long as you remove the cam carefully, reinstall the new cam carefully, and get the timing correct. Remember to change the oil after the first 50-100 miles.
  9. #9 Re: Cam install questions
    Dec 2013
    Rochester, NY
    sorry guys, forgot to say that. I'm doing the zzp push rods because I'm going ls7 lifters, double roller timing chain, and zzp cam install kit.
  10. #10 Re: Cam install questions
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I've got stock pushrod with my LS7 lifters. No issues so far in 3k/6 months.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  11. #11 Re: Cam install questions
    ^ pow
    Seems to be a hit or miss some guys need shorter pushrods some don't best way is to measure.
    04 Comp G.
  12. #12 Re: Cam install questions
    Québec
    Honestly, I didn't even pay attention, just checked if they were straight, cleaned good, installed them back on the LS7 lifters as if they were stocker. Lifters are just a wee bit noisier than the stock ones, (Even though my stock ones were sticky, which is why I went LS7, I didn't go with em for performance or anything anyways.)
    I'd say that if the engine's gone through two real oil changes since the cam install, that it's doing pretty good so far.
  13. #13 Re: Cam install questions
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    it strikes me as odd that pushrod length would possible change since LS7 lifters are stock replacement.
  14. #14 Re: Cam install questions
    Jun 2011
    Quote Originally Posted by danomite02 View Post
    The issue comes from the fact that the preload tolerance is tighter on the LS7 lifters then the L67 lifters.
  15. #15 Re: Cam install questions
    Jul 2011
    CT
    The GM dealerships must be changing to custom length pushrods if they ever replace the lifters in 3800s lolz
  16. #16 Re: Cam install questions
    Banned
    CT
    LS7 lifters are stock lifters.
    There I said it.
  17. #17 Re: Cam install questions
    Jun 2011
    Ls7 lifters are not the same as L67 lifters otherwise they would be called the same thing. For stock cam applications LS7 lifters will work with stock pushrods. But it seems the XP cam has a smaller base circle and it (sometimes it appears) throws the lifter preload out.
  18. #18 Re: Cam install questions
    You might need injectors and I'd start with a 3.4 pulley
  19. #19 Re: Cam install questions
    Dec 2013
    Rochester, NY
    Okay, so what I'm getting so far is 3.4 pulley not 3.3, why is the pushrod situation so controversial? And 105# springs. zzp claims 140# or 125#s. Why not use those?
  20. #20 Re: Cam install questions
    Jun 2011
    It's not that it's a big deal. Just make surf if your going to use LS7 lifters you take the time to measure lifter preload so you are sure to get the correct length pushrods.
  1. questions regarding cam install
    By hammer489 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2013, 07:33 AM
  2. I am looking to install an aftermarket HU...just some questions.
    By 08GPguy in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2012, 09:22 PM
  3. Questions after powerlog install.
    By Bluemagic in forum General Tech Discussion
    Last Post: 05-27-2012, 09:05 PM
  4. intercooler install questions
    By screamingreenmonster in forum General Tech Discussion
    Last Post: 05-17-2010, 05:17 PM
  5. ZZP MPS Install questions
    By Liquifire in forum General Tech Discussion
    Last Post: 10-13-2009, 02:21 PM
