Thread: ZZP MPS Install questions
Results 1 to 3 of 3
  1. #1 ZZP MPS Install questions
    Wausau, WI
    This is probably a ridiculous question, but I want to be sure before I attempt the install of this MPS. This is an eight rib MPS from zzp. I have a six rib belt...question number one-is the belt centered on the pulley or does it go more to the inner or outer? question two-after pulling the stock pulley and installing the MPS hub how do I know when I am at the proper mounting depth for the hub. Does it only go on so far, or how else do I know. Thanks for the help once again guys...
  2. #2 Re: ZZP MPS Install questions
    i centered mine on the pulley, but if it isnt sitting right it will move itself when the motor is running.
    i put the hub on flush with the end of the snout so the pulley was the thing hanging out the farthest and the pulley will sit flush with the end of the snout as well.
  3. #3 Re: ZZP MPS Install questions
    Banned - Busted For Scamming
    Feb 2009
    Yes you press it on till the shaft is flush with the end of the hub. Just like the stock pulley.
  1. 04+ HUD Install
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-06-2012, 02:25 PM
  2. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
  3. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  4. need help with LOC install!!!
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2008, 04:00 PM
  5. Handful of Questions for an Intercooler Install
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2008, 07:27 AM
