Thread: Spirited Turns followed by Power Steering Whine/Groan
Results 1 to 11 of 11
  1. #1 Spirited Turns followed by Power Steering Whine/Groan
    GTP Level Member
    Aug 2012
    st louis park, MN
    So I recently put in new kyb quick strut assemblies, lca's and front poly sway links and just had an alignment done. I wanted to feel out the car a bit so I wen to a big lot and did some really easy back to back turns. I was hearing a couple clicks under light turning and I kept turning back and forth while moving (maybe like 40 turns?) just to listen. After that I did about 6 hard corners at about 35 and came to a hard stop. When I took off I had a big whine/groan from what I assume was the power steering. I know these are a bit noisy to begin with but this was very noticeable. Turning didn't seem to make the groan but accelerating and revving the engine did.
    I checked the fluid and it seems at an appropriate level. The sound was quieter this morning but it has me wondering if I damaged something with all that turning.
    Any thoughts? Thanks for any input.
  2. #2 Re: Spirited Turns followed by Power Steering Whine/Groan
    SE Level Member A98GTP's Avatar
    Apr 2014
    Texas
    Was the clicking like a metallic popping like a CV joint going bad maybe?
  3. #3 Re: Spirited Turns followed by Power Steering Whine/Groan
    St. Louis
    Check the level of your transmission fluid- fully hot, car idleing in park, level ground. Could be it whining from the hard cornering.
  4. #4 Re: Spirited Turns followed by Power Steering Whine/Groan
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by A98GTP View Post
    Not sure. It was a noticeable click noise when steering back and forth. It was at the same point of the steering wheel in both directions. I'm not sure what that would be...
    Quote Originally Posted by FordMan77 View Post
    I will certainly check the fluid. Why would the transmission whine like that? When I stopped really hard after cornering and went to accelerate, it did clunk pretty hard into gear and then the whining started. I don't know why, but I didn't think that was related. I would guess the fluid isn't low but could the transmission still whine like that from the driving conditions I put it through, even with the right amount of fluid? And why would it do it revving in neutral?
    Thanks gents!
  5. #5 Re: Spirited Turns followed by Power Steering Whine/Groan
    Oct 2011
    Toledo, OH
    Fluid might not be low in the PS, but you may need to bleed it.
    7"
  6. #6 Re: Spirited Turns followed by Power Steering Whine/Groan
    Enfield, CT
    ^^^ this or maybe the bearings in the pump are goin
  7. #7 Re: Spirited Turns followed by Power Steering Whine/Groan
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by industrialfish View Post
    Sound was not noticeable this afternoon when I drove about 40 miles round trip. Is the power steering system self bleeding such that, if last night, I somehow got air in the system it would bleed itself over the next couple of drives?
  8. #8 Re: Spirited Turns followed by Power Steering Whine/Groan
    Feb 2009
    flintnasty MI
    Clicks when turning are usually strut mounts going bad, did you replace them (correctly) when you did struts?
  9. #9 Re: Spirited Turns followed by Power Steering Whine/Groan
    GTP Level Member
    Aug 2012
    st louis park, MN
    New strut assemblies - no shortcuts. I'm going to check that all bolts I touched are tight. The only uncertain thing was how tight to get my moog poly sway bar links. I didn't want to crush the poly bushings so I only guessed at how tight they should be ...
  10. #10 Re: Spirited Turns followed by Power Steering Whine/Groan
    Feb 2009
    flintnasty MI
    Well I am literally in the same boat as you... I assumed my strut mounts are bad which was causing strain on the power steering. Ill let you know if I find any answers.
  11. #11 Re: Spirited Turns followed by Power Steering Whine/Groan
    GTP Level Member
    Aug 2012
    st louis park, MN
    My whine is gone, by the way. Not really sure if it was the transmission or the power steering but let's just say I'll be keeping the spirited driving for the gsxr and the track, lol.
  1. power steering whine
    By Orange04CompG in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 11:30 AM
  2. Power Steering whine
    By nickgpgt in forum General Tech Discussion
    Last Post: 05-26-2013, 07:38 PM
  3. power steering whine?
    By Garrett Mofford in forum General Tech Discussion
    Last Post: 10-19-2012, 04:37 PM
  4. power steering whine on turns
    By Warbeaver in forum General Tech Discussion
    Last Post: 06-04-2010, 08:21 AM
  5. Power steering whine on left turns only...
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 12:19 PM
