Thread: Cam install questions
Page 4 of 4 FirstFirst ... 234
Results 61 to 72 of 72
  1. #1 Re: Cam install questions
    Florida
    You don't have to remove the balance shaft, you DO have to remove the balance shaft gear.
    You can leave the balance shaft in place, or remove it, but then you will have to block the oiling holes.
  2. #2 Re: Cam install questions
    Dec 2013
    Rochester, NY
    Will removing the gear do anything?
  3. #3 Re: Cam install questions
    It'll give you enough clearance to get the double roller in there.
  4. #4 Re: Cam install questions
    Florida
    Removing the gear will allow clearance for the double roller, and it will keep the balance shaft from spinning.
    The balance shaft is designed to counter engine vibration at idle.
  5. #5 Re: Cam install questions
    Dec 2013
    Rochester, NY
    okay, I just wanted to make sure that pulling the cure of wasn't gonna do anything damaging. It doesn't matter if I just leave the shaft in there?
  6. #6 Re: Cam install questions
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    No most people leave it in there since it is easier then pulling it out and plugging the holes.
    If You Cant Hear The Whine You're Too Far Behind...
  7. #7 Re: Cam install questions
    Florida
    Nope, no damage. Much easier than having to pull it then try and block the oil passages.
  8. #8 Re: Cam install questions
    Dec 2013
    Rochester, NY
    Alright everyone, here's my updated list for my project. Got about a month before I start on her and I'm just getting your opinions again.
    Tog headers
    3.4 pulley
    60lbs injectors (going e85)
    130 springs
    Double roller
    Should I still stay with stock push rods and lifters? And s friend said I should go sx1 not xp. Is there a huge difference between the two cams?
  9. #9 Re: Cam install questions
    There is not a big difference between the two cams. I consider them interchangeable.
    Why the 130# springs?
  10. #10 Re: Cam install questions
    Dec 2013
    Rochester, NY
    Got a good deal on them and a few people said I might as well run them since I have the double roller.
  11. #11 Re: Cam install questions
    Yup.. sounds good.
  12. #12 Re: Cam install questions
    Dec 2013
    Rochester, NY
    Only have one question left. What plugs should I run?
  1. questions regarding cam install
    By hammer489 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2013, 07:33 AM
  2. I am looking to install an aftermarket HU...just some questions.
    By 08GPguy in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2012, 09:22 PM
  3. Questions after powerlog install.
    By Bluemagic in forum General Tech Discussion
    Last Post: 05-27-2012, 09:05 PM
  4. intercooler install questions
    By screamingreenmonster in forum General Tech Discussion
    Last Post: 05-17-2010, 05:17 PM
  5. ZZP MPS Install questions
    By Liquifire in forum General Tech Discussion
    Last Post: 10-13-2009, 02:21 PM
