matt5112
Do you mean Knock Retard or actual Knocking occuring in the engine?
The KR is always real because Knock retard is the retarding of the timing that is occurring due to the PCM picking up what it believes is knock from the knock sensors. It doesn't matter what is causing it to pull the timing. If the PCM is pulling timing and reporting KR, the KR is real.
The cause for the KR can be false, as in the knock signal can be falsified.
Unless you guys have a different defintion of KR from say the GM service manual or the HPT manual.
