ill copy it here for ya.
Jack and support passenger side front of car.
Remove tire
Remove plastic splash shield in front of harmonic balancer
Untension belts
Remove crank bolt (24mm)
Using a balancer puller and m6 x 1.00 pitch bolts about 60-75mm in length pull the balancer
Disconnect crank sensor electrical
Remove plastic crank sensor shield
Remove crank sensor (2 x 13mm bolts and wiggle it)
Reverse for installation.
Tip, when reinstalling the plastic crank sensor shield. Ensure each of the three nubs have clicked on the bolt ends.
