Thread: Getting stuck gasket of throttle body?
Results 1 to 7 of 7
  1. #1 Getting stuck gasket of throttle body?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    Ive been told that you should use a razor blade but when i tried that it ****ing nicked the **** out of it even when i was careful it would always nick. I now picked up some gasket removal foam **** and that didn't work at all, for now i'm just gonna drench the remaining stuck gasket chips with the gasket removal foa m overnight for hope any real suggestions?
  2. #2 Re: Getting stuck gasket of throttle body?
    The Boss Iceman6669's Avatar
    Jun 2011
    #1. Use the search function... We just had a thread about this...
    #2. http://www.amazon.com/Stanley-28-100...ref=pd_cp_hi_0
    2011 F-150 Yote powered
    Quincy, Mass
    There is gasket remover stuff in a can that you get. But you'll still to use a razor blade, just be careful and slow.
    No more GP 04 Impala SS Indy:
  4. #4 Re: Getting stuck gasket of throttle body?
    Feb 2008
    I have no idea how you are making marks on it, I've always removed gasket material with a razor. I actually use the Stanley one Iceman pointed out. You're using the flat end... right..?
  5. #5 Re: Getting stuck gasket of throttle body?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    how are you holding the razor blade?
  6. #6 Re: Getting stuck gasket of throttle body?
    i dont get it either, this should have been done before cleaning it. and how can it be "that" stuck on there?
    rip it off with a belt sander, yeah that will do it.......
  7. #7 Re: Getting stuck gasket of throttle body?
    3m pad with a drill and or air grinder.
  1. How to remove stuck gasket from throttle body?
    By RideWithPride in forum General Tech Discussion
    Last Post: 07-30-2012, 05:27 PM
  2. Throttle stuck
    By MIke79 in forum General Tech Discussion
    Last Post: 06-14-2011, 09:35 AM
  3. Throttle body
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 06:43 AM
  4. Throttle body gasket?
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:46 PM
