Thread: Timing or other issue after L67 to L32 swap
Results 1 to 20 of 38
  1. #1 Re: Timing or other issue after L67 to L32 swap
    Apr 2012
    Chicago
    So since I have a day office job - gave car to my dad to take to shop. Wires were checked and were fine, re-tourqued the knock sensors yesterday. I got car back last night - went for quick test drive. In 1st gear car did not break up, hesitate, etc. Gradual acceleration pressure seemed fine, so did one test to wind through 1st gear and car ran like a champ (temporary cautious optimism). Tried again where I can get into 2nd gear, this time in 2nd gear, same symptoms of engine shut down. Got a flashing SES light for 20 seconds, then computer resets and is gone. (no scanner at home to see what code is)
    Pulled back into garage at home, checked for any obvious signs for source of vacuum leak. Double checked the throttle body adaptor bolts. 2 were not overerly snug and I was able to torque down another 1/16 of a turn. Take car back out for test ride. Almost same results, this time at top of 1st gear, SES comes on and stays on. So done driving and back to the shop for scan.
    Before a parked for the evening, I tried one test by just coasting at about 25-30 mph, then manually downshifting to 2nd and then tried to accelerate - experienced cycling hesitations almost immediately. Very odd it would not do that in 1st.
    To answer Ricos question - the L67 suffered a spun bearing at 91k miles. The bearing was paper thin so must have been a long time issue. Part of the reason I switched to the L32 was hoping the factory rods and bearings would fare better.
    So back to the drawing board - will plan to scan, check fuel pressure, etc. Will try to post engine bay picture some time in the next day or so. There was one extra vacuum port on the Gen 5 SC that did not exist on the Gen 3, so we just plugged it - not sure what it ran to in the L32 engine bay. Because this an inconsistent issue and a used jy engine, I'm betting something may have been damaged either in the yard or during transport (we used the L67 knock sensor because the L32s were damaged), so I'm thinking something else is sending incorrect or conflicting information to the ECM.
  2. #2 Re: Timing or other issue after L67 to L32 swap
    Quote Originally Posted by 67goat View Post
    Bingo... get us a picture or verify what it is in the pictures I'm about to post
  3. #3 Re: Timing or other issue after L67 to L32 swap
    Is it the one with the hose attached or the one just to the left of it?
    Hose is pcv. This must be hooked up or you are possibly building pressure in the crankcase...which..btw would cause it to fall on it's face. PCV gets routed between map and throttle plate.
    If you have an L67 TB and want to make the pcv functional, follow the first 4-5 pics in the first post of this thread to drill and tap your L67 TB. Then run the hose from that pcv nipple to the new nipple you put in your TB. If you need more pics..holler. I have this on my car.
    Other one is the L32 evap hole and needs to be plugged and or have the evap routed into it. It's easy to tap with a 1/4" npt and put a nipple in it to put the vacuum hose to it. I know..cause I did it last night.
  1. Timing
    By redskinman73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2011, 01:48 AM
  2. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  3. Top swap issue
    By Enzo354 in forum General Tech Discussion
    Last Post: 03-03-2011, 01:00 AM
  4. Timing belt swap
    By Ryan D. in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-03-2010, 04:54 PM
  5. Issue with fbody caliper swap.
    By Merlin in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2009, 04:55 PM
