Thread: Timing or other issue after L67 to L32 swap
Results 1 to 20 of 38
  1. #1 Re: Timing or other issue after L67 to L32 swap
    Map sensors are two different connectors. Likely he kept his L67 sensors.
    I'm running a Gen V off an L67 tune. It's not that far off in actuallity because both blowers displace 90 cubic inches of air per revolution. Hence the M90 designation Gen V handing off a cooler charge.
    Injectors..he's likely running his stockers. Since he can't swap the L32 rail on. but if not..great idea.
    I'm thinking lean/vacuum based on the fact that it idles nice and light acceleration works well. Anything beyond that and as long as you aren't in boost.. ...hmmm now to rethink this. Do me a favor..triple check your plug wires. Make sure you have them right. Because it's possible to cross a couple and have it run nice and then go to hell at load etc. I know usually it idles like crap..but there are a couple cylinders you can do and have it be off. Trust me. lol
  2. #2 Re: Timing or other issue after L67 to L32 swap
    Apr 2009
    Fort Worth TX
    This is what I'm doing. Rewire connectors and solder the pressure regulator and return line in there and you're done. I know it's unnecessary but it'll be different.
    I'm sticking with your first inclination...lean and mean.
  1. Timing
    By redskinman73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2011, 01:48 AM
  2. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  3. Top swap issue
    By Enzo354 in forum General Tech Discussion
    Last Post: 03-03-2011, 01:00 AM
  4. Timing belt swap
    By Ryan D. in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-03-2010, 04:54 PM
  5. Issue with fbody caliper swap.
    By Merlin in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2009, 04:55 PM
