Thread: Timing or other issue after L67 to L32 swap
Results 1 to 20 of 38
  1. #1 Re: Timing or other issue after L67 to L32 swap
    Apr 2012
    Chicago
    Ha! Will check Boosty! My brother did the install and he's a FT mechanic, I assumed he would've not plugged somthing as simple as a PCV. If that is it, he will never live this one down. Will let you all know the results...
  2. #2 Re: Timing or other issue after L67 to L32 swap
    Oh...also..make sure that evap hole isn't wide open. That would cause a lil problem too.
    PS.. you didn't mention the plugged stuff in your first post. I see you are holding back info... did I ask for pics? hmmm probably would have seen that in pics....if the slacking OP had posted 'em.
  1. Timing
    By redskinman73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2011, 01:48 AM
  2. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  3. Top swap issue
    By Enzo354 in forum General Tech Discussion
    Last Post: 03-03-2011, 01:00 AM
  4. Timing belt swap
    By Ryan D. in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-03-2010, 04:54 PM
  5. Issue with fbody caliper swap.
    By Merlin in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2009, 04:55 PM
