what is the IATand how important is it if i just left it dangling
its a intake air temp sensor, it tells the car the temp of the air entering the engine, so inside the cone works. or zip tie it to the cone, rip open the mesh a bit for the zit tie to fit, and done, zip ties seem safer for the wires to me, hide it on the back side i guess.
I used the Silicone coupler from Spectre with a small 45* polished elbow (looks).
Drilled a 7/8 hole into the rubber for the IAT and cleaned it with an exacto knife. Fit well and tight. With the filter (9" Spectre) it wasn't too expensive, close to $60.
Iceman6669 thats exactly what i want to do to make it look just like that! but dont forget my original goal was to make the supercharger whine more
GTLGDP thats what i was looking at doing putting an spectra filter about that size on the end like that but did you have to tuck any sensors or anything like that? did it through any codes?
Will this set-up work on an 04+? I like Coolone's setup. It looks neat. Do i have the same sensors?
