Thread: need some intake help
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 need some intake help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i have a bone stock gtp and i basically wanna make the super charger louder (the whine) ive been reading around and people say the open cone intake will cause it to be louder. what i was wondering is can i just slap a cone filter on the end of the stock tubbing or do i need to buy some special set up?
  2. #2 Re: need some intake help
    St. Louis
    You can put a cone on the end of the TB, or you can buy some tubing from Lowes and make an extension down closer to the drivers headlight.
    The Boss Iceman6669's Avatar
    Jun 2011
    ^^^ this^^^
    Slap a cone right on the end of the TB and call it a day... That's what I did and works well. And yes the S/C will whine like an infant if you punched it..
    2011 F-150 Yote powered
    Ohio
    What is it with all the intake threads? Use the search bar people. You can do it blindfolded
    Sent from my DROIDX using Tapatalk
  5. #5 Re: need some intake help
    Oct 2011
    Michigan
    can i just put a cone on the end of the TB? what about the MAF?
  6. #6 Re: need some intake help
    The year of your vehicle just became important. Please provide.
  7. #7 Re: need some intake help
    Feb 2009
    flintnasty MI
    I smelled 04+ on this post..
    Assuming so, you can just put the filter right on the maf. It works quite well.
  8. #8 Re: need some intake help
    Apparently from people that tune...
    Filter on the end of the MAF skews the readings...so if you go open cone...you need a little adapter OR a small amount of pipe between the MAF and the filter.
    Ohio
    What I did on my buddy's, was put the maf on the throttle body, then used a 3"-4" adaptor to go to 4" pvc and a 9" cone
  10. #10 Re: need some intake help
    Oct 2011
    Michigan
    i have a 1999 gtp
    Ohio
    Here's mine on my friends 04... Dam series 3 with puny ass TB's
    need some intake help Attached Images
  12. #12 Re: need some intake help
    Puny?
    I thought the L26/L32's were bigger than L67's...maybe not.
  13. #13 Re: need some intake help
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Mine goes down near the fenderwell a little bit, but i'm trying to slap one straight to the throttle body also. Is there a write up how to do this + pictures? I have all day to do something, i'm bored. 2000 GTP
  14. #14 Re: need some intake help
    this is what i came up with, i was unable to find a 90 deg elbow and used a 45. the cone straight off the t body dont seem to have the clearance so i used the elbow. i got a 6 dollar rubber couple with the metal band and 2 clamps on it, remove the metal band from the clamps, slid it on the t body and then the cone, drill a hole for the iat sensor, done.
  15. #15 Re: need some intake help
    ^^Cut that 90* in half. 45>90
    Steps to do an open cone?
    Rip off everything and bolt the cone to the end of the TB?
    Pretty straight forward.
    IAT placement doesn't matter either...because it's gonna get hot regardless.
    Ohio
    Yeah nick, the l67/36 are about 3.25-3.5 while the l32/26 are around 3.0 flat. Realize it as that the throttle body od is the same as the maf tube
  17. #17 Re: need some intake help
    i was going to cut it but in the middle its not the same dimensions of the outer lip where the filter is now, see what i mean? and not perfectly round either on the outside middle.
    Ohio
    22. 5> 45> 90
  19. #19 Re: need some intake help
    Quote Originally Posted by 99pgpgt View Post
    I was meaning the inner diameter...oh wellz. There isn't much material around the new DBW TB's...but there is quite a bit of material around the older ones.
  20. #20 Re: need some intake help
    So just open cone that ugly broad
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. ram air intake
    By jprovinsal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2009, 08:17 AM
